EEC IV FEMALE PINS - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 11-14-2014, 11:37 AM Thread Starter
EEC IV FEMALE PINS
Anybody have some spare female pins for the 86-93 mustang?i can't find them anywhere. Thanks
robertc68 is offline
post #2 of 7 Old 11-14-2014, 03:40 PM
Blown88GT's Avatar
Junkyard. Cut off the connector from any EEC-IV harness on any Ford.
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
post #3 of 7 Old 11-15-2014, 12:21 PM
4eyefever's Avatar
I had luck at my local Ford dealer,they were cool enough to let me in dig around in their parts room.The small drawer bins that had the most dust on them contained the correct EEC IV pins I needed.
Even as I type this I still can't believe they were nice enough to let me back there.I got some weird looks but can't say enough how helpful they all were.
Good luck
2 owner '86 Med.Canyon Red Met.(original paint) T-top,5 speed,3.55 rear,MAF conversion(A9L).MM adj. RLCAs,T/A and Panhard Bar,spring rate:375#-440#,MM C/C plates,STB,4pt KMB,FLSFC's,'03 Cobra rack-n-pinion w/ Saginaw pump conversion.Bilstein MM coilover conversion and A-arms,spring rate:250#.
4eyefever is offline
post #4 of 7 Old 11-16-2014, 07:46 PM
How many do you need?
kbscobravert is offline
post #5 of 7 Old 11-16-2014, 08:49 PM
Blown88GT's Avatar
Junkyard ones already have the pigtail wire attached. Easier to lengthen than crimp, if you don't have the crimp tool.
post #6 of 7 Old 11-17-2014, 02:28 PM Thread Starter
4. Thanks
post #7 of 7 Old 11-21-2014, 10:39 AM
Originally Posted by robertc68 View Post
4. Thanks
Pm me your address
WOT Miss 306Guy 5.0/5.8 Engine Tech 29 09-28-2013 09:07 AM
custom wiring the stock eec harness... HELP speedracer1000 Electrical & Wiring 0 06-26-2012 07:12 PM
Possible fried EEC? scott88 General Mustang Tech 10 04-13-2012 10:20 AM
Changing EEC matthewx 94/95 Tech 3 11-26-2011 07:29 PM
