Circular connectors for TE connectivity - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 10-03-2014, 12:37 PM Thread Starter
Stangu2fast's Avatar
Circular connectors from TE connectivity
Has anyone used their connectors? I ordered some awhile back to wire my megasquirt properly. I'm thinking of installing the 57 pin connector this winter.
1985 Mustang LX Coupe
302, Carb, Performer Heads, B-303
1987 Mustang LX Coupe Factory 302,MS2
Stangu2fast is offline
post #2 of 3 Old 10-06-2014, 10:24 AM
The top connector is an AMPSEAL. No wire-to-wire versions, but we use them in the MS3-Pro harnesses. You have to make sure the pins are centered before you close the shell on them, but they work great.
No experience with the others.
Matt Cramer
Matt Cramer is offline
post #3 of 3 Old 10-08-2014, 07:46 AM
Blown88GT's Avatar
The bottom ones look like MIL-DTL-38999 connectors. Good enough for aircraft, spacecraft, etc, good enough for anything you're planning.
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
competition engineering subframe connectors mr_minnis General Mustang Tech 9 09-14-2014 07:15 PM
Who runs subframe connectors AND thru floor connectors? gr8_96gt Road Racing/Auto X 8 12-31-2013 05:27 PM
round tube subframe connectors sen2two General Mustang Tech 4 08-22-2013 01:14 PM
Redneck Sub-Frame Connectors - advice needed TxFireman1972 General Mustang Tech 23 03-21-2012 08:31 PM
NEED: Help Identifying Connectors 95PGTTech 5.0/5.8 Engine Tech 14 02-10-2012 10:29 AM
