ccrm delete - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 09-16-2014, 08:36 PM Thread Starter
ccrm delete
I'm looking to clean up alot of wiring while I do my swap and the ccrm is one thing I can't figure out if I can actually get rid of.. I'm swapping a 6.0 in (I know I know) and I'm leaving the factory ford PCM in so I can use the factory gauges..and I read somewhere that the ccrm has a relay in it for the pcm..is this true or can I go ahead and get rid of it..i will have my fan and fuel pump on switches
94lsgt is offline
post #2 of 6 Old 09-17-2014, 06:13 PM Thread Starter
Bump
94lsgt is offline
post #3 of 6 Old 09-17-2014, 09:14 PM
Yes, the CCRM contains the PCM relay.
Here is a pin out diagram:
https://forums.corral.net/forums/11276621-post17.html
2dxtrm is offline
post #4 of 6 Old 09-27-2014, 01:33 PM Thread Starter
Thank you
94lsgt is offline
post #5 of 6 Old 09-29-2014, 02:08 PM
If you only have the pcm on the ccrm just run a regular relay and save yourself the extra wiring and work.
kbscobravert is offline
post #6 of 6 Old 09-29-2014, 04:41 PM
kb1982's Avatar
What year is your car? If it is a 94, the guage clusters recieve the signal directly from its dedicated sender, and not from the pcm.
kb1982 is offline
Smog delete prior to H/C/I or during 1cheapMF 5.0/5.8 Engine Tech 2 11-12-2013 01:18 PM
Need help ditching my CCRM kbscobravert Electrical & Wiring 7 03-06-2013 10:42 PM
98 GT Won't start. No Injector Pulse. No power to fuel pump. Shawn 94 GT GT & SOHC 11 10-23-2012 07:48 AM
Bondurant Electrical Wiring Fan CCRM A/C WOT Cutout Modification rallycobra Road Racing/Auto X 1 06-26-2012 12:24 PM
Can I delete my AC delete with Wazee PS pulley frankstang Superchargers 9 02-10-2012 08:37 PM
