Will a Fox C&L MAF housing work in a 94-95? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-27-2014, 03:00 PM Thread Starter
I recently bought a basketcase 95gt and found 24lb injectors and a C&L sample tube/housing in it for a foxbody with 24lb injectors, it's one of the units you stick your stock MAF in. My question is can I use this housing in the 95 with the stock 95 maf without issue? I am going to loose money selling this thing and buying the correct one so I would rather not. The setup is a stock bottom end/Fcam/Procomp 175cc heads and intake/t5.
Honda's are like ********, everybody has one.
smokehouse_83 is offline
post #2 of 3 Old 09-16-2014, 07:17 AM
Blown88GT's Avatar
C&L recently retired after 21 years & sold the business to MAC Performance. His old website is back online. Not all the links are working.
C and L Performance
MAC website for C&L:
MAC Performance Motor Cycle & Automotive, Parts & Accessories
There were 2 housings, 73mm & 76mm. Sample tubes are the same for both, but there are different colors (calibrations) for different setups.
'94-'95 (SN95) are the same engine as the '87-'93 (Fox)
The calibration tube is dependent on the location of the air filter, i.e. directly on MAF inlet or power pipe or forced induction. Therefore, there may not be a simple answer, depends on more info that you have not provided.
BTW,
1. You don't "stick your stock MAF in"; you only use the sensor from the stock MAF.
2. "The setup is a stock bottom end/Fcam/Procomp 175cc heads and intake/t5. " - Not Relevant to the MAF
Without knowing exactly what C&L stuff you have now, can't say if it's correct or not. As many that get this right, get it wrong, giving C&L a bad rap. Remember, his stuff worked when the only ECU's were Ford EEC-IV.
cnlperformance.com
Look at the Table
You should have the 76mm housing with a Black Tube (#105); it's colored on one end of the sample tube; color does not come off, unless you grind or polish it off. Some tubes are clear (#101).
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
post #3 of 3 Old 09-16-2014, 09:54 AM Thread Starter
Thanks, but after I posted I did a bunch of research and found out all about these mafs. I have the correct tube for my car.
For Sale C&l 80mm maf housing and 24lb sample tube jeffmarble Fuel System & Related 1 08-30-2013 11:20 AM
C&L MAF on your Supercharged Fox RTW0223 Superchargers 14 08-19-2013 10:37 PM
c&l 73mm maf housing issues RUN-1T 5.0/5.8 Engine Tech 4 10-03-2012 12:29 AM
For Sale JLT RAI For 99-01 Cobra or Mach with C&L MAF Housing Ossy305 Modular Engine Parts 1 09-13-2012 11:34 AM
On3 has done it again...... 2Guard Turbochargers 179 08-13-2011 03:29 AM
