Installed Wideband, how to wire into ecu? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 06-29-2014, 12:20 PM Thread Starter
Installed wideband, wired power and ground, it says I can wire in the brown wire into the factory o2 sensors and relay narrow band information. Where do I wire it into? A pin on the ecu or a down stream wire? Also for the data logging feature, I am not sure how to hook it up to the laptop, I know the aerial output but how does log works get all the other information like rpms, map, fuel tables and such? Is it wired into the ecu? I do have an SCT 4 bank chip with custom tunes from Willie lynch of it helps any. I really appreciate any and all help
87NotchBack5.0 is offline
Voltage Regulator Wire 89KenneBellVert 5.0/5.8 Engine Tech 11 05-24-2013 03:20 PM
Do you guys see a singular problem in these codes hotrodt 5.0/5.8 Engine Tech 35 01-30-2013 06:11 AM
Car shut down while driving and will not restart, HELP! shdowconspiracyx 5.0/5.8 Engine Tech 15 09-10-2012 02:31 PM
New Build with Acel Gen 7 HELP with Wire Harness Ideas? mgmid7070 Engine Management Systems 3 08-16-2011 08:07 PM
Adios old kitchen, it's been a fun-filled disgusting last 3 years. Dave88LX Lounge 258 05-05-2011 09:09 PM
