Anyone experiment with larger injectors on SD system? (Adding displacement) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 06-03-2014, 05:30 PM Thread Starter
ratio411's Avatar
Question Anyone experiment with larger injectors on SD system? (Adding displacement)
I have a 5.0 SD setup on my F150 (and my 87 Stang), and I want to increase the engine size from 302 to 408. I know the biggest thing with SD is keeping the idle smooth, then everything should fall into place just fine so long as I can increase the fuel to match the increase in air...
If this works on my truck, I might just do it on the Stang too... It won't kill me not to run a lumpy cam on a purely street driven car if I have the cubes to make it go.
The truck has an electronic transmission that is not supported by any factory MAF system, so without going to an expensive Baumann controller stacked on a MAF ECM, it pretty much has to stay SD.
Anyway, if I run larger injectors, will the SD ECM run them just like the stock 19s, but since they are larger injectors, they will add more fuel???
I know this seems overly simple, but it sounds reasonable. Am I missing something?
I did the math, and if you enlarge the 19# injectors by the same percentage as the increase in engine size, and I come up with 25#s. So, if my theory holds true, 24s might just work. Assuming that the injector rating means that they add that much more fuel with the same signal received from the ECM as compared to the 19s.
Thoughts?
1987 GT 5.0/T5/3.55 [My Toy]
1990 F150 Lariat 5.0/E4OD/4.10 [My DD]
1981 Fairmont Futura 5.0/T5/4.10 [Son 1]
1994 GT 5.0/AODE/4.10 [Son 2]
ratio411 is offline
post #2 of 11 Old 06-03-2014, 05:33 PM Thread Starter
ratio411's Avatar
I have a set of 24s, and a set of 30s... so experimenting is not a problem.
I just want to make sure that I won't hit a dead end that I cannot overcome if I go through with this. It would be an expensive dead end.
ratio411 is offline
post #3 of 11 Old 06-03-2014, 11:36 PM
Just Chuck's Avatar
Put a two bar map on it and some 39# injectors from a terminator.
1989 LX 5.0 - 333 Mexican block, Eagle 4340 neutral3.25" crank, Probe SRS 9cc dome .040 psitons AFR 185 Comp heads, FTI HR cam 239/244 613/613, Edelbrock Victor 5.0, 90mm TB, BBK 1 3/4, C4 and 4500 Circle D converter, 4.10 gears
2012 GT/CS 5.0 - Yellow Blaze Tri-Coat metalic, A6, HID.
Just Chuck is offline
post #4 of 11 Old 06-04-2014, 06:05 PM Thread Starter
ratio411's Avatar
In laymans terms, what will that do for me?
What is the difference between the stock MAP and a "2 bar"?
Will the 2 bar plug in and function with the stock ECM without conflict?
Thanks!
Dave
ratio411 is offline
post #5 of 11 Old 06-04-2014, 07:25 PM
Just Chuck's Avatar
Stock map is 1bar or 1 atmosphere.
If you put a 2 bar map on, it would cut the VE table in half and this cut the required fuel in half. Thus a 39# injector should be within the limits of adaptive control when paired with a 2 bar map
You could even a run a blower up to 14.7 psi in theory.
post #6 of 11 Old 06-04-2014, 07:50 PM Thread Starter
ratio411's Avatar
I have since Googled the subject, and it seems that the "bar" is the limits of the MAP's ability to function, and doesn't affect what it reports to the ECM. 2 and 3 bars are used on boosted applications for their ability to read pressures beyond 1 atomosphere, not for any ability to "double" readings. The readings are exactly the same, they just read over a wider range.
Therefore your theory of doubling info sent to the ECM is incorrect. It's the same info, the MAP just has the ability to read twice the range of pressure than a 1 bar. Not of any use to a non-boosted engine.
ratio411 is offline
post #7 of 11 Old 06-04-2014, 07:54 PM Thread Starter
ratio411's Avatar
My dyno tune guy says the best way to tune stock SD for changes in displacement is simply finding the injector size that gets close, and then using an adjustable FPR to make the fine tune.
This way the factory tune can be used just fine, so long as the camshaft is chosen for smooth idle, but more importantly high vacuum.
So it sounds like I am on the 'right track'.
ratio411 is offline
post #8 of 11 Old 06-05-2014, 11:09 AM
Just Chuck's Avatar
True, but the voltage scale of the output is cut in half. Regardless of the MAP sensor, they all output on a 0-5V scale.
post #9 of 11 Old 06-05-2014, 09:00 PM Thread Starter
ratio411's Avatar
Interesting... but why do I only find guys using them for boost?
I'd be interested to hear about people using them on n/a engines.
ratio411 is offline
post #10 of 11 Old 06-12-2014, 08:29 PM
liljoe07's Avatar
Trader Feedback: (18)
Because boost guys need the added range or they peg the sensor, you dont really need them for an NA car. Hes suggesting that MAP sensor as an alternative to try in order to use larger injectors. In a way, its like using a Mass Air thats calibrated for an injector size.
Cutting the MAP scale in half(going to a 2 bar), lets you run an injector thats twice as large. In theory!
89 Coupe: POS
Tuner: QuarterHorse, BE & EA, AEM Wideband
liljoe07 is offline
post #11 of 11 Old 06-12-2014, 08:33 PM
liljoe07's Avatar
Thats a long ways away from what I think the proper or best way is. Cheaper.....yes, best....not a chance.
89 Coupe: POS
liljoe07 is offline
For Sale Fox Fuel system A1000, lines, injectors, MAF 97SVT Fuel System & Related 16 11-01-2012 11:41 AM
On3 has done it again...... 2Guard Turbochargers 179 08-13-2011 03:29 AM
For Sale Weldon Pump , Injectors, Fuel system parts White85gt Fuel System & Related 3 07-07-2011 08:16 AM
my 1992 mustan is making a beeping noice inside the cab. oze4272 General Mustang Tech 21 06-16-2011 03:37 PM
For Sale Glenns Performance fuel system parts/ Deka 60lb injectors 999rocketman Fuel System & Related 12 02-03-2011 08:02 PM
