no upshift 4R70W after converter change - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 06-01-2014, 12:32 PM Thread Starter
I have a 97 4.6L TBird project car that upshifts at 5100 rpm WOT. After installing a 3800 stall converter last year I had problems with an early 1-2 (4700) and late 2-3 (5500) shift. It had a Hypertech chip. I removed the chip and I'm using a SCT 3015 controller. Now it won't shift 1-2 at WOT at all. I've let it go to 5900 and still no shift. At 90% throttle it will upshift, no problem. The speedo is correct however I even tried replacing the 20T speedo gear with a 17T to make the speedo read about 10 mph higher but no upshift. The controller doesn't seem to have a WOT rpm change only a mph change which hasn't fixed it either. I've used an old Ford Trans tester that allows manual upshifts using an electrical switch which I can shift without any problem. Anyone run into this? Thanks.....Ken.
BadShoe Productions, Instructional repair videos specializing in Ford drivetrains
kennethl6 is offline
post #2 of 2 Old 06-11-2014, 09:23 AM
Don 95Vert's Avatar
Pull the converter and replace the O ring on the shaft. Probably got damaged and will not allow tranny to build enough pressure...
95 Lightning - Slow
95 Convertible 357 turbo
10.5/135 @ 3800#
SCT Tuned
Don 95Vert is offline
For Sale 4r70W, PI L/U converter, & Shifter For Sale. (NO REVERSE ON TRANS) blake_yount Drivetrain Parts 5 06-10-2014 09:36 AM
For Sale 03 Mach1 4r70w Torque converter donnie42091 Drivetrain Parts 2 05-06-2013 09:58 PM
For Sale FS: 4r70w with transbrake pi converter 750.OO sucks2bu Drivetrain Parts 14 02-18-2011 05:20 PM
For Sale 4r70w torque converter and sensors BayyGT Drivetrain Parts 1 02-12-2011 03:25 AM
