Spark plug question... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-04-2014, 04:42 PM Thread Starter
I've got a 347 with Dart aluminum heads and a turbo. I've just recently converted from my MSD with a single coil to MS3-Pro coil on plug using the LS truck coils. The question that just occurred to me, should I change from the standard plugs to iridium ones? I know that my GM V6 ran like crap with conventional plugs (I tried to cheap out on a tune up) and I had to change back to the iridium ones. Would that be based on the coils being used, or the ignition, or does it have something to do with chamber design? I know that the iriduims are supposed to last longer, but had I not tried the standard ones in that Impala I never would have realized the difference. I'd love to hear from people that have had experience with this in a semi-drag car.
MNtony is offline
post #2 of 5 Old 05-07-2014, 03:41 PM
I'm not running a turbo but I run a 393 with those coils and I'm using standard plugs. I don't see any reason to change them.
Megasquirt
seijirou is offline
post #3 of 5 Old 05-13-2014, 09:11 AM
Ive just been running 3923's with the ls coils, i am going to try NGK's this season though. No drivability problems to speak of, but if you do try it post your results here, id be curious to know if it makes any difference.
Street car with a 5 speed
427ci SBF -- 9.86 at 136mph
http://youtu.be/2GKQ2xpZraU
Drag Week 2013 SR/SB/NA Winner
Doc's Notch is offline
post #4 of 5 Old 05-13-2014, 11:51 AM Thread Starter
I've been running the NGK's up until now. I was just wondering if there was an iridium requirement with the LS coils. Sounds like that is not the case from the responses. I will probably just stick with what I have for now.
MNtony is offline
post #5 of 5 Old 05-13-2014, 02:52 PM
The iridium plugs are more of a longevity thing than anything else, so they can advertise 80,000+ mile spark plug replacement intervals.
Matt Cramer
Matt Cramer is offline
MMR Spark Plug Gapping tool for 2005-2008 Mustang GT Mod Mustang Racing S197 and Coyote Parts 132 08-03-2017 02:25 PM
spark plug question meastang Turbochargers 3 04-06-2012 03:31 PM
Spark Plug Question eightysixmustang 5.0/5.8 Engine Tech 4 04-04-2012 01:41 PM
1986 efi no spark at plug asv 5.0/5.8 Engine Tech 3 05-24-2011 03:37 PM
Ignition Systems and Spark Plug Gap Question Quik5oh 5.0/5.8 Engine Tech 5 12-06-2001 10:18 PM
