ford dizzy 8-1 ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-01-2014, 10:53 AM Thread Starter
indio84's Avatar
ford dizzy 8-1 ?
Hello,
I'm looking for a ford 302 small block dizzy with a
late GM pattern trigger - 8 teeth the same width, plus 1 extra tooth (so there are two sensors inside), for cylinder #1.
Any info apreciated
Part number or model of the dizzy helps a lot
indio84 is offline
post #2 of 4 Old 05-01-2014, 09:15 PM
Blown88GT's Avatar
You must have a unique reason for wanting something that probably doesn't exist. Ford hasn't offered a distributor on a vehicle in 20 years.
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
post #3 of 4 Old 05-02-2014, 12:23 AM
The tfi dizzy does exactly that. One edge of the teeth are evenly spaced, the other edge is uneven for one tooth giving you tdc. If you can't work with reading both edges from a single sensor like that you can always epoxy a magnet to the reluctor over the odd tooth and add a VR sensor to the dizzy.
Megasquirt
seijirou is offline
post #4 of 4 Old 05-02-2014, 09:27 AM
If you need two sensors, that's what is called a dual sync distributor. There's a couple of companies that make them for Fords - although oddly enough, I'm not aware of any GM car that used a dual sync distributor from the factory.
Matt Cramer
Matt Cramer is offline
Junkyard Horsepower SUMMARY! slo5oh 5.0/5.8 Engine Tech 231 01-30-2015 11:35 PM
For Sale 1992 Ford Mustang LX Coupe For Sale flashman Mustangs For Sale/Wanted, 1987-1993 1 07-22-2013 11:37 PM
For Sale Ford Duraspark Dizzy with Steel Gear! Superlead76 Windsor Engine Parts 0 02-13-2012 06:29 PM
