Chip burning and MAF sensor - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-25-2014, 03:32 PM Thread Starter
I will be converting my car over to MAF and will have a chip burned and I have a couple questions to make sure I spend the money where it needs to go.
MAF sensor, does it need to be matched to the injectors 24maf - 24injector?
Since I'm having a custom tune done does the ECM matter as far as which one I get? I know it has to be MAF but should I still get a A9L ecm or any MAF ecm since I'm having a custom chip made?
bigtimegearhead is offline
post #2 of 2 Old 04-26-2014, 09:42 AM
Decipha's Avatar
no, the maf does not need to be matched to the injectors, in fact I ONLY recommend getting a "calibrated' MAF for 60lb injectors for the foxbodys despite your actual injector size
as long as the ecu is a MAF ecu from an 89-93 foxbody they are all the same hardware and can run the same chip no problem
check out the pre tune info for more in depth details
Pre Tune Information / EFIDynoTuning
decipha @ EFIDynoTuning
www.efidynotuning.com
Decipha is offline
Is tuning really not necessary for a bolt on car? 4rd Tough 94/95 Tech 67 01-27-2014 10:46 PM
Who is Best at Burning Custom Chips for Specific Mods? BULLITT680 GT & SOHC 2 12-02-2001 08:14 PM
