Can tyou swap a A9L for a 93 cobra computer? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-29-2014, 09:39 AM Thread Starter
Trader Feedback: (43)
Can you swap a A9L for a 93 cobra computer?
I currently run a A9L PCM with 24# injs and a BBK mass air calibrated for #24's. Can I swap out my A9L and use a 93 cobra PCM? What is the main differences between the two?
Just an old carpenter with a 94 Cobra and a Son with a nasty 85GT! I'm Show and he's Go!!
XSPOWER is offline
post #2 of 4 Old 04-02-2014, 08:12 AM
Please call me Mike
mr_minnis's Avatar
Trader Feedback: (46)
yes you can. Will run right ? I don't know. Remember the Factory ECU where calibrated for the maf transfer fuction. The X3Z was setup for the 24s. I am not sure what BBK did to scew the curve. If you ran a cobra MAF it would be fine.
From what i have read there really isn't any advantages to running the Cobra. You can get both tuned equally well. I would only do it if you are wanting to put Cobra parts back in your Cobra
here is a link to one of the threads:
https://forums.corral.net/forums/engi...a-ecu-a9l.html
84K 88 LX Vert 5spd: 3.73s.
mr_minnis is offline
post #3 of 4 Old 04-02-2014, 08:29 AM Thread Starter
Do these A9L computers ever go bad and act silly or are some more forgiving than others? I ask because over the years, I've seen so many posts of guys who have surging and then just as many guys reply who say they've never had a problem with it and they are all using a A9L. Seems like it would be more consistent. My cam is so mild that I carry 16-17 inchs of vac. at idle which is not that much less than a stocker. My son's 85GT is carbed but he only has 9 inchs at idle. Thanks Guys!
XSPOWER is offline
post #4 of 4 Old 04-22-2014, 02:21 AM
Indo-Canuck-Yankee
Shaker666's Avatar
All of the '89-93 EEC-IV computers (generally speaking A9L, A9P, X3Z, A3M, etc.) run what is known as Ford's GUFB engine control strategy. Any of these computers can run any other calibration, ie. an X3Z computer can run A9P, however a tuning device is required. Something like the TwEECer, Moates Quarterhorse, etc.
If you're not planning to tune and you're currently running A9L and thinking about swapping to an X3Z ('93 Cobra), think twice. The X3Z is tuned to use 24 lb injectors, so the BBK MAF calibration will cause some problems.
'71 Mach 1: totaled - R.I.P.
Shaker666 is offline
For Sale 1994 cobra (full terminator swap) wldtang Mustangs For Sale/Wanted, 1994-1998 28 04-02-2014 09:19 PM
For Sale 1993 Cobra Computer X3Z 85ksp Electronics and Entertainment 1 05-23-2013 11:02 PM
For Sale 03/04 Cobra swap parts, fuel tank, and misc. DOHC engine parts Trav4011 Modular Engine Parts 8 10-31-2011 05:14 PM
For Sale tank, and03/04 Cobra swap parts, misc. DOHC engine parts Trav4011 Modular Engine Parts 1 10-22-2011 11:28 PM
93 cobra with A9L computer, exhaust and S-trim, how much HP? blk91gt Superchargers 4 11-26-2001 05:47 PM
