87 XR4TI - TFI module, Knocking? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 01-13-2014, 08:50 AM Thread Starter
My 87 Merkur XR4TI had a gray TFI and I was given a Black TFI module. Engine starts, but there is a loud knocking sound that sounds more like a lifter. Could the wrong TFI module be causing this?
Just FYI, I replaced the valve cover gasket with a blue rubber "permanent" type. After that, no spark, replaced the TFI and not the knocking....
Could the wrong TFI be causing this?
dalich is offline
post #2 of 3 Old 01-13-2014, 11:08 PM
black is not the right one
turbo c is offline
post #3 of 3 Old 01-14-2014, 09:06 AM
You need a grey "push start" TFI module, not a black computer controlled dwell module.
Not sure why the knocking because it wouldn't change the timing, but it will run way too much dwell with the black module which can damage the module and the coil.
Megasquirt
seijirou is offline
Tags
tfi, xr4ti
For Sale 94-95 Ford Mustang TFI module Michael Plummer Electronics and Entertainment 7 09-28-2013 06:49 AM
For Sale 302 TFI distributor & TFI Module Macs Stang Windsor Engine Parts 7 11-26-2012 12:59 PM
For Sale FS: Stock distributor with TFI module and tool included OBO - PICS! DuffManRHA Windsor Engine Parts 1 11-11-2012 04:08 AM
Hard Starting caused by bad TFI module palacios289 5.0/5.8 Engine Tech 6 08-17-2012 12:59 PM
Is my TFI module dieing?? blackstallion 5.0/5.8 Engine Tech 1 01-07-2002 07:46 PM
