Haltech Sport 2000 Install in 8 second true street car - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 44 Old 12-29-2013, 09:58 AM Thread Starter
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
I am going to use this thread to document our installation of a Haltech Sport 2000 complete setup in my 89 true street car.
The list of things we are doing is as follows:
Haltech Sport 2000
Haltech Wideband Kit
Haltech IQ3 Racepak Dash
Custom Haltech provided wiring harness
The list of sensors are:
Turbo backpressure
Pressure before the intercooler
Transmission line pressure
Fuel pressure
Oil pressure
Due to that we eliminated all of the gauges except transmission temperature
I will be adding very detailed tech here but wanted to get the ball rolling with a first set of pictures.
We got started last night on getting the harness roughed in, racepak and Florida 5.0 cluster fit and the electronics mounted under the dash.
The Florida 5.0 plate is nice. The IQ3 does require trimming plastic in the housing that goes around the cluster. Will post pictures shortly.
The harness was custom made for the specific electronics and configuration of my car.
We made an aluminum plate to mount the box to due to it needing to be secured from behind and then attached the new plate to the aluminum panel under the dash.
mcj50 is offline
post #2 of 44 Old 12-29-2013, 12:20 PM
Michael Plummer's Avatar
Trader Feedback: (87)
First off, I've asked the Corral if they could add Haltech, Holley and
Pro-M Engine Management Systems to the dedicated Sub-forums like the ones above so far my inquiries have fell on deaf ears. If more ask, maybe we can get it accomplished.
Looking forward to reading about your installation, tuning and overall usage of the system. FLF, did a great write-up on his installation but would of liked to see more of the tuning and overall usage on the system.
849rwhp and 771rwtq SAE
Pro-M Racing EMS
Michael Plummer is offline
post #3 of 44 Old 12-29-2013, 04:20 PM
MCJ50,
Looking forward to your latest build.
Which coil and ignition box have you selected ?
-1989 LX, 3" exhaust-
6 Liter Fox is offline
post #4 of 44 Old 12-30-2013, 07:02 AM Thread Starter
mcj50's Avatar
The Florida 5.0 panel sits the IQ3 racepak slightly recessed but the shape of the Racepak requires trimming the center of the cover before it goes on.
As you can see in the picture the center is now completely open. We continued to trim until the cover fits without hitting the racepak and is under no force.
I eliminated the cowl mounted gauges on my car as well as a shiftlight since the racepak will provide that functionality.
mcj50 is offline
post #5 of 44 Old 12-30-2013, 07:14 AM Thread Starter
mcj50's Avatar
Used SEM vinyl and plastic spray that I have had laying around to clean up a used but not cracked cowl panel.
mcj50 is offline
post #6 of 44 Old 12-30-2013, 07:15 AM Thread Starter
mcj50's Avatar
Originally Posted by 6 Liter Fox View Post
MCJ50,
MSD Grid 7730/7730/7761
HVC2 coil
mcj50 is offline
post #7 of 44 Old 01-05-2014, 07:28 PM Thread Starter
mcj50's Avatar
We mounted the IQ3 and the Florida 5.0 panel.
It required trimming due to the size of the iq3.
We also grabbed some led's to make up turn signal indicators, high beam indicators and a red light for when the MSD traction control is active.
Everything is mounted up on my pre-existing aluminum panel. Cleaner then the huge boxes from the accel DFI
That will be cleaned up further once we connect all of the wires.
Wednesday night we should have much of the interior wiring done.
mcj50 is offline
post #8 of 44 Old 01-05-2014, 09:00 PM Thread Starter
mcj50's Avatar
Battle plan:
mcj50 is offline
post #9 of 44 Old 01-08-2014, 02:12 PM
Not really familiar with everything the MSD grid system offers.
However I understand it controls many timing events and some data recording.
Wont the Haltech system do all this making the grid unit not necessary ??
Thanks.
post #10 of 44 Old 01-08-2014, 03:43 PM Thread Starter
mcj50's Avatar
Thanks.
I am currently using the MSD GRID to control rev limiters (burnout, footbrake, transbrake, rev limit). I also added the 7761 and a driveshaft RPM sensor for traction control. This was all in with the Accel DFI I had removed which did not offer these things.
Our current plan is leave the MSD setup as is and focus on converting everything over that had been controlled by the DFI.
We will be working on the car all night tonight.
Mike
mcj50 is offline
post #11 of 44 Old 01-08-2014, 11:37 PM Thread Starter
mcj50's Avatar
The relay box is finished. The Haltech relays are set to trigger from ground so we altered my override switches to use ground. We also changed the way their box is wired so for those two relays they are not energized by switched ignition so we can run the fans and pump with the car off.
Also re wired line lock and one trans fan because of other changes.
I spent the night setting up a newer laptop with all if the necessary software.
mcj50 is offline
post #12 of 44 Old 01-09-2014, 11:09 AM
redhoss's Avatar
Very Nice build. I am looking forward to seeing your progress.
JP
Fox Stock Block 5 speed [email protected]
redhoss is offline
post #13 of 44 Old 01-15-2014, 10:46 PM Thread Starter
mcj50's Avatar
I had Florida 5.0 send me their lights for the dash:
Turn signals, high beam, and a red for traction control from the MSD 7761.
Ryan was otherwise re wiring things all night.
We are working again in am, hopefully will have some better updates.
Mike
mcj50 is offline
post #14 of 44 Old 01-15-2014, 11:36 PM Thread Starter
mcj50's Avatar
The list is getting shorter.
mcj50 is offline
post #15 of 44 Old 01-16-2014, 02:12 PM Thread Starter
mcj50's Avatar
Wiring in the back of cluster:
Default Haltech IQ3 screen layout
We tested a number of things, blinker indicators, high beam indicator, traction control indicator, radiator fan, trans cooler fans, water pump. It all works.
There is some minor clean up needed still in the car but it is about 90% ready for the motor.
I started installing the sensors that are for pressure, pre-intercooler and manifold pressure, both 5 bar.
mcj50 is offline
post #16 of 44 Old 01-16-2014, 04:37 PM
93alexcoupe's Avatar
Nice write up, that iq3 looks real nice. By any chance does it show fuel level?
Built by Lujan Motorsports
Boss 308ci BullseyePower Turbo, ProEfi.
93alexcoupe is offline
post #17 of 44 Old 01-16-2014, 04:44 PM Thread Starter
mcj50's Avatar
Yes, we have the factory signal wire wired to an input on the Haltech and we are going to use some rocket science to convert the signal for display on Haltech.
Trying to dodge the $135 racepak part. More to come.
mcj50 is offline
post #18 of 44 Old 01-18-2014, 07:44 PM
How and who do we ask to get this sub-four up, Great idea.
black 93 lx is offline
post #19 of 44 Old 01-20-2014, 03:40 PM
redhoss's Avatar
Any updates?
redhoss is offline
post #20 of 44 Old 01-20-2014, 10:00 PM Thread Starter
mcj50's Avatar
Headed out again Wednesday night. We are nearing completion until the motor is back.
mcj50 is offline
post #21 of 44 Old 01-21-2014, 05:03 AM
93SVTvenom's Avatar
Looking good ... Nothing like a shorter list to push through to the end ...
2016 ZX10R - stock for now
1993 Mustang Cobra - built for RR/Show ... all stock bits saved (For originality
2015 GMC Canyon SLT 4x4 - My daily driver
93SVTvenom is offline
post #22 of 44 Old 01-23-2014, 04:07 PM Thread Starter
mcj50's Avatar
I just ordered two more temperature sensors:
-oil temp
-transmission temp
I am going to change strategy on one thing, I think I'm going to put the transmission temp displayed through the racepak and put a fuel level gauge in the spot I have in my radio panel for transmission temp. I currently have an ultralite pro comp gauge which is very visible in silver. Will order a black gauge so it is nondescript.
mcj50 is offline
post #23 of 44 Old 01-25-2014, 02:00 AM
-oil temp
-transmission temp
I stocked up on these fluid sending units. 1/8"npt and a 0-5v reference. Autometer can send you the temp graph...I have it somewhere.
Auto Meter
They use these Metripak connectors...verified by Autometer techline
EFI Connection, LLC - Connector Details
As long as you can costomize the the inputs for the Haltech and you have a 5v reference signal you can have the Haltech monitor anything.
My plan is to put a fluid sensor pretty much everywhere but I am using Holley Dominator EFI.
kbscobravert is offline
post #24 of 44 Old 01-25-2014, 02:38 PM Thread Starter
mcj50's Avatar
Auto Meter
The sensors came directly from Haltech. They ship with the plug and pins to splice into an input and the ECU has the temp graph pre-loaded.
It was too easy not to do.
mcj50 is offline
post #25 of 44 Old 02-06-2014, 12:01 PM
If it helps, leave a few extra unused wires run throughout in the case of future updates and plans. Everyone that wires a car 3 months latter goes crap.. wish I had run XYZ. Perfect example would be a new boost controller.
Looking good,,
1989 GT 348 A4, 4788 T4, Glide, FAST, DR's.. always on pump gas and Alkycontrol
Winner MMFF 1st Dyno shootout 901 rwhp 4/2012
Runner Up NMCA True Street 3/14 8.66 average
Yes... straight methanol addict.. no water
Razor89 is offline
post #26 of 44 Old 02-07-2014, 01:49 PM Thread Starter
mcj50's Avatar
The haltech harness has a number of extra inputs and outputs and a pass through wire to get under the hood.
We did well and only had to modify the relay setup slightly to allow for the fans to run with the car off.
They really helped expedite the process for us.
Picking motor up tomorrow and should have underhood shots of the finished wiring later this weekend.
mcj50 is offline
post #27 of 44 Old 02-07-2014, 05:33 PM
So i'm not the only one running next month that doesn't have a running motor in the car
Mine should ready Monday..
Good luck with the process. I understand been there dun that
Razor89 is offline
post #28 of 44 Old 02-12-2014, 07:10 AM Thread Starter
mcj50's Avatar
The motor is back in the car. I will take some pictures of the harness and sensors tonight. Everything fit well.
Sent from AutoGuide.com App
mcj50 is offline
post #29 of 44 Old 02-12-2014, 01:04 PM
redhoss's Avatar
Look like you still need a hair dyer? Lol
redhoss is offline
post #30 of 44 Old 02-13-2014, 12:41 AM Thread Starter
mcj50's Avatar
Back pressure sensor setup. Not sure how well the cushion clamp will do in the heat but it did work well.
mcj50 is offline
post #31 of 44 Old 02-13-2014, 07:40 AM
Attachment 211258
On mine I used a steel fitting and tig'd it on. Then ran copper tubing to the sensor
the install looks pretty, don't know if you needed that thick of a tube too it. 1/16 would have been fine..
Razor89 is offline
post #32 of 44 Old 02-13-2014, 07:44 AM Thread Starter
mcj50's Avatar
I had copper here and I wasn't comfortable with it. Copper is soft enough that you could break it ir junk it working on the car.
Those parts were a total of $15, I am not worried about it being overkill.
mcj50 is offline
post #33 of 44 Old 02-13-2014, 10:59 PM Thread Starter
mcj50's Avatar
The car is running.
We had a good day today of really learning and understanding how the crank trigger and distributor work in conjunction with one another. We also spent time understanding the right way to phase the distributor. I suspect we did not have this done right with the DFI and that may have been one of the reasons we were burning up caps and rotors. We have this one dead on at 23 degrees of timing where we are at full boost.
I have to commend Haltech for excellent support. We identified a few challenges late last night and had answers and a revised map sent back to us first thing this morning. Following that the car started right up. A breath of fresh air vs. the DFI where a breathing human being was an impossibility to find.
The car had an open turbo flange and was sucking through the intercooler so we didn't get a true sense for how it is running.
My turbo is tracking for tomorrow AM. Assuming it fits without further work I will have it running correctly tomorrow night.
Feels good to be getting closer.
mcj50 is offline
post #34 of 44 Old 02-14-2014, 07:58 AM
Awesome update. I assume you will put some pics of the Turbo in your other thread?
post #35 of 44 Old 02-16-2014, 07:16 AM Thread Starter
mcj50's Avatar
For some reason I can't post pictures in that thread...but I can here. I may post it here if I don't have a better place for it. I still don't have the turbo, UPS is majorly screwed up due to the weather.
mcj50 is offline
Want To Trade wtt 91 lx 10sec street car for 2000 up mustang badstang351w Mustangs For Sale/Wanted, 1999-2004 1 10-20-2011 12:09 PM
For Sale 2003 Twin Turbo Cobra, Fully Built, Show Car cobramac Mustangs For Sale/Wanted, 1999-2004 4 07-09-2011 06:47 PM
