P0171 code System Too Lean Bank1 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 12-18-2013, 08:08 AM Thread Starter
I have a 98 v6, just got the spark plugs and wires, o2 sensors and fuel filter changed less than a week ago. Now, my car is popping up with P0171 (System too Lean Bank 1). One of my good buddies said fuel injectors. Would that be a good cause of this? As of my knowledge they are still the factory stock.
chemustry is offline
post #2 of 3 Old 12-23-2013, 01:17 PM
It is a possible cause. Swap your injectors from the passenger side to the driver's side and see if the problem moves to bank 2.
If it doesn't, it's not the injectors.
Megasquirt
seijirou is offline
post #3 of 3 Old 01-01-2014, 10:56 AM
svtfiend's Avatar
This could be one of many problems. Intake gasket leak, clogged/bad injector, could even be an exhaust leak around your o2 sensor. Do you have a scan tool that you can watch fuel trims and other live data on? It could save you a lot of time.
91 Thunderbird SuperCoupe- 95 Cobra motor swap with 5 speed. Eibach springs & Tokico struts. Mac headers with hiflow cats into Flowmaster exhaust, Trickflow springs, E-cam, 24# injectors, T4M0 ecm
svtfiend is offline
my 1992 mustan is making a beeping noice inside the cab. oze4272 General Mustang Tech 21 06-16-2011 03:37 PM
Who has access to Oasis reports? straightliner1 Lounge 4 02-28-2011 01:19 PM
After suffering for 2 1/2 yrs, down to code 91 only! dannyUAL91GT 5.0/5.8 Engine Tech 10 01-27-2011 12:40 PM
Our new race Thrust Bearing System >> Mod Mustang Racing SVT & DOHC 1 04-21-2010 10:46 PM
