Engine Management - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 12-01-2013, 12:42 AM Thread Starter
Engine Management
hi
i have mustang 67 302 engine vortech s\c with carb .
i went to swep to efi .
i have ho intake and 42 lb injector
im looking for self tuning Engine Management ecu for fuel injection.
what is recommended ?
dudi is offline
post #2 of 6 Old 12-03-2013, 11:17 AM
Are you just looking for basic fuel and ignition control, or are you looking for more? The biggest question is what features you need.
Matt Cramer
Matt Cramer is offline
post #3 of 6 Old 12-06-2013, 12:47 AM
Originally Posted by dudi View Post
hi
Nothing is going to self tune spark, keep that in mind.
Otherwise it depends on what you specifically need, as Matt asked.
If you don't know specifics, take a step back and figure that out. You definitely don't want to buy something without really knowing what your needs are.
Megasquirt
seijirou is offline
post #4 of 6 Old 12-06-2013, 02:36 AM Thread Starter
hi
i think i will use static timing at 20 degree
so all i need is fuel mange
dudi is offline
post #5 of 6 Old 12-06-2013, 08:44 AM
The spark advance curve is at least as important as fuel for making good power. But a MegaSquirt-II (or MicroSquirt) would be great for fuel control on its own with the option to go to spark control later.
Matt Cramer
post #6 of 6 Old 12-06-2013, 02:31 PM
hi
Any of the standalone solutions will work for you.
Because your needs are so basic I would recommend Megasquirt2. It is much less expensive than the others but will do what you need just as well as the others.
There are a couple of different ways to get a MS2 system. If you need a more specific recommendation we'll need to know if you need the simplest possible "bolt on" system, or if you're okay with rolling up your sleeves and doing solder work as well as building the necessary harnesses from scratch.
Megasquirt
seijirou is offline
03/04 cobra engine swap into 96-98 cobra raslobra98 SVT & DOHC 45 11-11-2014 02:30 PM
For Sale New AEM 30-1401 Engine Management System blownbuick Electronics and Entertainment 2 02-26-2014 05:58 PM
For Sale AEM 30-1400 Engine Management Pure Stock Electronics and Entertainment 11 08-14-2013 10:56 PM
What Engine Management System are you using? P63 94/95 Tech 13 03-15-2012 11:21 PM
For Sale 87-93 anderson pms engine management drexel Electronics and Entertainment 3 03-06-2012 01:17 PM
