problems with rev limiter please help!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 11-21-2013, 07:20 PM Thread Starter
93 mustang 302. v1 blower car.
i have done everything i can think of to raise the rev limiter.
I am using sniper software with an a9l. also a msd 6al is on the car set to 7000 rpm.
here is what we have done....
1. set the pip to 858 which should equal 7k
2. lightning maf
3. 60lb injectors
4. msd box
5. plugs at 30
6. set limiter to 7k in tune.
will not go above 6250 and hits limiter. im driving myself crazy please help
Cudablue1 is offline
post #2 of 4 Old 11-22-2013, 06:22 AM Thread Starter
Anyone??
post #3 of 4 Old 11-22-2013, 07:01 AM
TooSlo86's Avatar
So you have these set like this?
NLM_CL RPM - Rev Limit - Fuel Cut Off (Fuel Returns) 6900 RPM
NLM_SH RPM - Rev Limit - Fuel Cut On (Fuel Cut) 7000 RPM
NLMT RPM - Rev Limit Max RPM (Fuel Cutoff) 7200 RPM
And you're sure it's 6250 and not actually 6500 that you are hitting the limiter? I'm not sure how the above look with the sniper software.
Have you messed with the speed limiter by chance?
TooSlo86.com
[email protected] during NMRA Factory Stock qualifying @ Norwalk. [email protected] in eliminations on the new 308 w/unported P-heads and Explorer intake @ 3050lbs. ALL MOTOR. Now for a good clutch!
TooSlo86 is offline
post #4 of 4 Old 11-22-2013, 08:37 AM Thread Starter
It is 6250 on my tach shift light is 6500 and never lights. I'll check the tables tonight.
how can i raise rev limiter in 95GT? 66KIX 5.0/5.8 Engine Tech 2 12-25-2001 03:37 AM
Need to raice rev limiter in my 91. Whats the cheapest way?? jz_mustang50 5.0/5.8 Engine Tech 0 12-18-2001 10:57 PM
Did 94-95 GT have rev limiter ? 281cobra 5.0/5.8 Engine Tech 0 12-17-2001 01:38 PM
options for bypassing the factory rev limiter??? pkstang 5.0/5.8 Engine Tech 1 12-15-2001 07:47 PM
Bumped Rev Limiter, now its dead, HELP! Jerry 5.0/5.8 Engine Tech 15 12-09-2001 08:00 PM
