75mm Pro M MAF Transfer - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 11-19-2013, 11:11 PM Thread Starter
I'm certain that this has been requested 1000x's, but does anyone have the MAF Curve for a 75mm Pro M calibrated for 42# injectors in a 93 LX 5.0 using at A9P EEC and I'm using the TwEECer for making the changes.
I have already adjusted the Injector High and Low slopes to reflect.
42.000 or injector HIGH
51.500 for injector LOW
Now I need to have the curve numbers. I've been told to use the numbers that are in the EEC and raise their values 121% and it will be close. I also know the TwEECer software has a MAF folder that has the ProM42 MAF numbers and I want to cross check.
[FONT=Comic Sans MS]93' 5.0, New 306 Block, E303 cam, Y303 FRPP Aluminum Heads, Edelbrock RPM upper and lower, BBK 70mm throttle body, 1.7 roller rockers, 340lph fuel pump, Borg Warner 5-speed , 3.27 gears, 3-core aluminum radiator, Upper and Lower Rear control arms, On3 Performance Turbo/FONT
Red5Ltr is offline
For Sale 75mm Pro M / Pro Flow MAF danond Fuel System & Related 6 11-18-2013 10:18 AM
For Sale 88-93 75mm Pro M MAF W/24# injectors $150 shipped candyfox510 Fuel System & Related 0 07-08-2013 01:03 PM
Need MAF circuit help for 92 5.0 MFE General Mustang Tech 23 06-05-2013 10:04 PM
Please help no one else can g3mustang General Mustang Tech 155 06-13-2012 09:11 PM
For Sale PRO M 75MM MAF MARCIN306 Electronics and Entertainment 1 02-23-2012 04:54 PM
