Setting timing... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 11-14-2013, 03:50 PM Thread Starter
Setting timing...
Ok, I'm an MS3-Pro newb here so please forgive me. I am almost complete with the wiring and I am trying to figure out how to set my cold timing. A little background is that I am using the LS coils on my Ford for a coil near plug setup.
What I need to know is if I set the timing so the crank is at top dead center, or should I align it for a total amount of timing that I want like the MSD setups do? Essentially allowing the MS-3 to pull timing out instead of allowing it to add timing to the initial.
Another question is if when I set the sensor if it should be on the leading edge of the tooth or the trailing edge? I think that I've read leading edge.
Additionally this is using the Hall sensor (3-wire) that I purchased from DIY and it utilizes a stock Ford cam sensor. The wheel is a 36-1 (of my own design) with an 5 tooth lead from the blank.
MNtony is offline
Balancer painted, how to see the timing marks? Wicked03GT 5.0/5.8 Engine Tech 9 06-26-2012 01:53 PM
PMS Timing??? Proudsuperior PMS Tuning 10 04-07-2012 12:31 AM
timing and heat gator72007 Turbochargers 8 01-07-2012 10:45 AM
IMPROVED DRIVABILITY: E-fan to mech + new timing chain IJCOBRA 5.0/5.8 Engine Tech 8 11-09-2011 10:08 AM
MS2 vs MS2 Extra seijirou MegaSquirt DIYAutotune Systems 23 04-12-2011 05:54 PM
