log aem wide band help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 10-24-2013, 01:59 PM Thread Starter
g3mustang's Avatar
Trader Feedback: (18)
there used to be a right up in eectuning.org that had this.
does any one know how ot hook up a aem wideband to binary editor?
afr 185 heads, dss 331
Turbo build
g3mustang is offline
post #2 of 7 Old 10-24-2013, 08:58 PM
liljoe07's Avatar
Mine is done through the EVP circuit. Can only be done that way if you are not using the EGR. Otherwise you need to get something like the dataQ.
89 Coupe: POS
Tuner: QuarterHorse, BE & EA, AEM Wideband
liljoe07 is offline
post #3 of 7 Old 10-25-2013, 10:48 AM Thread Starter
g3mustang's Avatar
im not using egr can you please give me a more in depth on how this is done?
Turbo build
post #4 of 7 Old 10-25-2013, 12:14 PM Thread Starter
g3mustang's Avatar
do i just tie it into pin 27 and thats all i have to do?
Turbo build
post #5 of 7 Old 10-25-2013, 08:21 PM
liljoe07's Avatar
Yes, then you have to set up BE to read the EVP as AFR. You will tie Pin 27 to the 0-5v output on your wideband. Which version of BE do you have?
89 Coupe: POS
liljoe07 is offline
post #6 of 7 Old 10-26-2013, 10:45 AM Thread Starter
g3mustang's Avatar
I have the latest version. How do I tell the BE to read as afr.in the dashbord it just says to click it to use as afr
Turbo build
post #7 of 7 Old 10-28-2013, 11:01 AM
Nevz86GT's Avatar
Open up the BE Help File and go to section 4.10.2 Custom Transfer Function (TwEECer / Quarterhorse).
This section will walk you through setting up BE to monitor a 0-5V analog input such as the analog output from your wideband into the bro/grn wire (pin 27) which is the EGR/EVP signal wire.
I just did this the other day and it was simple.
In the custom transfer function I renamed the EVP Tag to AFR. Once this is done your payload list in BE (used to select which parameters you wish to datalog) will no longer display EVP but instead will show EGR as the selectable parameter to datalog.
Nevz86GT is offline
MS3-Pro vs AEM PNP ECU kbscobravert MegaSquirt DIYAutotune Systems 2 05-29-2013 12:18 PM
Want To Buy Black gauge face for aem wide band tonylittell Electronics and Entertainment 4 05-24-2012 03:27 AM
For Sale AEM wide band a\f gauge 1Delsol2try Electronics and Entertainment 0 03-13-2012 11:46 AM
AEM wide band problems rustyruststang50 Electrical & Wiring 2 08-13-2011 01:18 AM
For Sale aem wide band o2 rwcblown88 Electronics and Entertainment 2 02-13-2011 08:37 PM
