1993 Cobra w/SSP ECM - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 10-10-2013, 09:18 PM Thread Starter
Cobra18's Avatar
I have an issue with what seems to be a vibration at 2500 rpms. I pulled out the ECM today and noticed that it says SSP on it. I called Ford and they informed me that the 93 Cobras have a specific ECM and cant use a regular mustang ECM due to the MAF being calibrated as 24lb injectors. Does this sound familiar to anyone? Also the idle surges when its cold and also at idle it almost seems like there is a miss and engine loading up...I am running a AEM cold air intake with a K&N cone filter on the end. I just need to know my next step as to whether replace ECM or replace MAF with one calibrated for 24lb injectors.Can the ECM be programmed to calibrate the MAF for 24lb injectors?
Cobra18 is offline
post #2 of 3 Old 10-16-2013, 06:41 PM
wytwolf's Avatar
May not be liking all the air from that open element filter. If you have the stock filter assy., put it on and see if it fixes the problem. You could get an aftermarket MAF cal'd for 24's. The computer won't need anything. It just receives a signal from the MAF. I'd bet on the CAI/filter being the issue though.
wytwolf is offline
post #3 of 3 Old 10-22-2013, 12:03 AM
Indo-Canuck-Yankee
Shaker666's Avatar
What MAF and injectors are you running?
'71 Mach 1: totaled - R.I.P.
Shaker666 is offline
For Sale 1993 Cobra x3z Ecm Bob 86 Electronics and Entertainment 4 11-03-2013 04:47 PM
For Sale Vibrant Red 1993 Mustang Cobra #4019 of 4093 cookcobra Mustangs For Sale/Wanted, 1987-1993 8 09-12-2013 11:14 PM
1994 - 95 Cobra grille: pony or snake? 1oldfox 94/95 Tech 57 04-19-2013 11:53 PM
For Sale F/S: 1993 Teal Cobra Osorio299 Mustangs For Sale/Wanted, 1987-1993 6 03-21-2011 11:49 PM
5 Lug Conversion questions...for a 1993 Cobra Osorio299 General Mustang Tech 5 01-30-2011 08:51 PM
