Aftemarket Engine Management Harness - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 09-25-2013, 10:41 PM Thread Starter
Has anyone here ever used either the Ford Racing, Painless Wiring or the Summit Racing engine management/ECM harness to replace your old, beat up original harness? What were your results? I've been chasing an intermittent runability issue for years and the only thing left questionable is the harness.
Thanks.
1989 F-150 SB 4.9 C-6
1987 F-250 4x4, 460, C-6
1974 Mercury Cougar XR7, factory 460, C-6.
brucifer is offline
post #2 of 7 Old 09-29-2013, 12:12 AM
pillowofwinds's Avatar
Im curious also. Im about one recommendation away from swapping to a carb. Ive had enough of the efi gremlins running around under the hood(and behind the kickpanel)
90 lx coupe - too big of heads and too big a cam, 4.10s
10.69 @ 127.8 NA stock bottom end
pillowofwinds is offline
post #3 of 7 Old 09-29-2013, 08:13 AM Thread Starter
I know how you feel! I've threatened to carb this car more times than I can remember. lol. But if I carb it, then I admit defeat and will never know what was causing the problem. Not quite ready for that yet.
I bought a low mileage harness from a forum member--it's currently in shipping. I'll report back on this thread once installed with the results.
brucifer is offline
post #4 of 7 Old 10-12-2013, 08:34 PM Thread Starter
Well, went to install the harness and it's not for a 1990 model.
brucifer is offline
post #5 of 7 Old 10-17-2013, 08:08 AM
neffarnie2's Avatar
Trader Feedback: (32)
If you are having drivability problems have you tried doing what this link says?
Fuel Injection Technical Library 10-pin Connector Fix
It is not just isolated to the 10 pin connectors but also to the computer connector, EGR connector, etc., all the ones that have the round pin design.
93 LX Hatch, Dart 363, TW 205 heads, RPM II intake, 80# inj, Glenn's rails, PP regulator, D1SC 14# boost, FTI blower cam, Stinger ECU, TKO 600, 3:73 gear, Eaton Posi, BBK longtubes, 3 inch LX exhaust, Strange 31 splines/9" ends, Baer Pro Plus and much more
neffarnie2 is offline
post #6 of 7 Old 10-19-2013, 12:06 AM
Trader Feedback: (41)
I have a BRAND NEW NOS EEC harness for a 90 Mustang if anyone is interested. It has never been installed.
stangjumper is offline
post #7 of 7 Old 11-05-2013, 06:40 PM
elsargeant's Avatar
I did get rid of my gremlins when I replaced my stock hardness on my 1989 with the Painless. Went to 347 supercharged and still have the same hardness, I'd say about 5 years.
elsargeant is offline
2000 GT SOHC to DOHC swap... (Using a 1997 Mark VIII Engine ) An82Mustang SVT & DOHC 53 04-02-2016 09:24 PM
For Sale a9l, 1989 engine harness, injector harness, and o2 harness FastASH Electronics and Entertainment 33 10-11-2013 01:14 PM
For Sale 93 Engine, Injector, & T5 harness zapp109 Electronics and Entertainment 2 02-12-2013 08:33 PM
92-93 Engine wiring harness 93foxnotch Electrical & Wiring 0 04-02-2012 06:16 PM
Changing engine harness, need help JimBowy Electrical & Wiring 3 03-21-2012 11:43 PM
