EXTREMELY weird NO start problem! HELP! 1988 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 09-25-2013, 10:23 AM Thread Starter
i have a 1988 mustang that I swapped a 93 5.0, the whole harness was changed over etc, the fuel pump is on a hot wire so it will always pump right now. When I go to start it, it starts but shuts off right away every time, has new ignition switch, tumbler, solenoid. Noooow the weird part...I can take the starter wire off the solenoid, ziptie the key in the START position and touch the wire to the solenoid to get it to crank and it will run perfect! I am Beyond confused with this as this is my first ford I have ever owned!
nalls426 is offline
post #2 of 2 Old 10-04-2013, 09:37 AM
TomR's Avatar
Check the run voltage on the coil and the TFI connector. You have some voltage tracing to do. You obviously have injector voltages and all start voltages, but lack run voltage for the ignition system someplace.
Maybe someone messed with the distributor wires, or installed a aftermarket distributor or ignition system incorrectly and it has key-start-position power but no key-run-position power? A voltmeter will tell that fast. Tom Moss has published wiring diagrams that are easy to find on line.
TomR is offline
Seized 5.0? Where to start? 1983Ttop5.0 5.0/5.8 Engine Tech 33 10-15-2013 04:54 AM
Weird Problem. Key start acts like key run. MikeSak General Mustang Tech 3 04-27-2013 02:09 PM
For Sale 1988 LX 5.0 - Mint / Show Condition arogant Mustangs For Sale/Wanted, 1987-1993 4 11-27-2010 08:26 PM
Starting Problem Ahhhh!!! (long story) silversleeper 5.0/5.8 Engine Tech 1 01-01-2002 07:39 PM
Cold start problem: Start, stall, Start Whiterag 5.0/5.8 Engine Tech 2 11-30-2001 06:53 PM
