Will I benefit from a tweecer or Quarterhorse - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-24-2013, 09:44 PM Thread Starter
Brian Smith's Avatar
Long story short. I have been racing for years but found it easier and cheaper to carb everything. Have had car s and helped others with theirs run in the 9's NA quite a bit. Now im 34, havve a wonderful wife and 3 beautiful gifts from GOD so i have put together a little street car.
1989 Coupe Regetta Blue. Explorer shortblock, AFR165 heads, TFS1 cam, 24lb injectors, PRO-M mass air and 24lb injectors with a Holley Systemax intake. 5 speed Pro Motion faceplated T5, with A9P computer. After several electrical struggles it is basically lined out. Surges some when warm but after 5-10 surges usually settles down. It runs a little rich at idle. runs decent at WOT. My question is, will I see a significant advantage to going to a piggy back system such a s the Moates Quarterhorse, or a chip burnt by ??? for my application, or should i keep it as is. (By the way, i have did several of these exact combos for locals and usually see 12.20-11.90 at the track in a 3100lb car and slicks)
1989 Coupe...Explorer shortblock, AFR165's, TFS1 cam, Holley Systemax, 70mm PP T.B., Pro Flow MAF, 24lb. inj. ProMotion Faceplated T5, 3.73's
Brian Smith is offline
post #2 of 4 Old 10-03-2013, 02:53 PM
TomR's Avatar
While you do not have major mods, the MAF meter and injectors will hose up the computer system a bit. Even if your MAF meter is calibrated for the injectors, it will still upset other things slightly. Generally the narrow band O2's will pull things back in if the changes are small, but you may not be getting into optimum rows of the dozens of tables.
The best and worse thing I ever did was buy an Innovate LM2, Tweecer RT, and retune my car. I can log everything now. I can record and know everything the EEC is doing. I can instantly tune the car so it starts and runs OK, even with huge changes in injector or MAF meters.
The only problem is a lot of conflicting and confusing information appears on the web. Some of the programs have areas that conflict with other tuning programs. Because of that, and the lack of non-jargon information that is complete, the learning curve is really way steeper than it needs to be.
For the first time in my life, I have spent as much time tuning and reading about tuning as I spend driving or doing mechanical work. I'm happy and grateful when I learn something, but frustrated at the time it takes.
I would say unless you have some desire to learn something that only applies to the EEC system you have, you are much better off just getting a tune somewhere.......except the data logging is super to have.
The best things I bought for watching my engine are the wideband O2 system and a J&S safeguard.
TomR is offline
post #3 of 4 Old 10-03-2013, 08:14 PM
Driveability and midrange can be improved by your tuning ability.
2007 BMW 335i
Goody_Seven is offline
post #4 of 4 Old 10-21-2013, 11:50 PM
Indo-Canuck-Yankee
Shaker666's Avatar
IMHO, with regards to the OP's original question, yes, however there is a steep learning curve in getting things to run perfectly. Fortunately, with a mild combo, very little needs to be tweaked; things like MAF curve, injector slopes, injector breakpoint, throttle body airflow, perhaps some timing curve adjustment. As the mods become more extreme with additional displacement and/or forced induction, there is no choice but to reprogram the computer.
I, as others, have spent several decades tuning carbs and over a decade tuning Ford EECs now. I take great pleasure in my tuning efforts, but I have spent countless hours researching and discussing on this forum and others how to solve specific problems. The end result is always sweet, but it requires patience, persistence, and resourcefulness.
'71 Mach 1: totaled - R.I.P.
Shaker666 is offline
Tweecer "Flash Failed" message genehart EEC Tech 2 06-11-2013 09:15 PM
Want To Buy WANTED: Moates quarterhorse or Tweecer RT Crock Electronics and Entertainment 0 09-10-2011 12:53 PM
MAF Tuning Correctly, TwEECer R/T & Quarterhorse Systems PowerAdder Solutions Engine Management Systems 0 08-28-2011 08:51 PM
Tweecer Help Needed Draggin90 Engine Management Systems 1 04-26-2011 04:59 PM
Want To Trade quarterhorse for tweecer lightning_2000 Electronics and Entertainment 6 11-25-2010 01:55 AM
