Help! Installing '99 explorer 5.0 / 4R70W into 70 Torino - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 09-24-2013, 02:42 AM Thread Starter
I'm sure this swap has been done a million times over by now... I'm new to it. I need a ecu (eec-v) that will allow me to run the distributorless ignition and control the automatic transmission. The wrecked explorer I purchased for a few hundred has the pats system and I want to get rid of it.... any suggestions with out me breaking the bank and going to the '93 5.0 ecm and having to run a distributor with a return style fuel system?
70_Torino_Guy is offline
post #2 of 3 Old 09-24-2013, 02:47 AM Thread Starter
The ,302-2v in the Torino now runs ok but the C4 auto is trashed. Wanted to run the stock 5.0L with the efi for my daily driver. I do not need anything special.
PATS sucks!
post #3 of 3 Old 10-24-2013, 09:13 PM
Indo-Canuck-Yankee
Shaker666's Avatar
You need an EEC-V, for sure. Something out of a '96-97 Crown Vic, Grand Marquis, T-Bird, Mustang, Cougar, or Towncar. The harness from one of these vehicles will have the EV1 plugs for the injectors, built in EDIS8, and controller for any of the electronically controlled transmissions.
You could also run an EEC-IV and wire it up for EDIS8. With the right tuning software, you can enable EDIS (because the EEC-IV does actually support it). You'll need the EDIS8 module from a '93 Lincoln Mk VIII or similar vehicle. Then you could run a separate transmission controller from Baumann Engineering or something like that.
There's a few routes to go there.
'71 Mach 1: totaled - R.I.P.
Shaker666 is offline
Help! My new to me JY Explorer 5.0 ate my distributor. fmyth 94/95 Tech 13 10-26-2013 01:00 PM
93 5.0 fresh explorer engine has slight rough idle and smoke S Spencer 5.0/5.8 Engine Tech 14 07-14-2013 09:49 PM
For Sale Parting Out Explorer 5.0 Motor 1slowhatch Windsor Engine Parts 15 06-15-2011 09:34 PM
water pumps - Explorer 5.0 *VS* SN95 Mustang 5.0 five_pointe_oh 5.0/5.8 Engine Tech 2 01-12-2011 05:20 PM
For Sale Explorer 5.0 Intake Manifolds 1slowhatch Windsor Engine Parts 6 12-22-2010 11:37 PM
