Self Tuning for 87 Coupe EFI - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 09-09-2013, 09:29 PM Thread Starter
GodStang's Avatar
I am building a 351w efi in a 1987 Coupe. I switch setups often so I would like to tune it myself. What route are people going now a days for self tune efi? Still Megasquirt? Other options? What all is needed? Any tips? I have done searching and maybe spelling it wrong but most stuff is 2 or 3 years old.
2003 SVT Cobra Sonic Blue w/E85 tuned by Bob Kurgan
On the Dyno at Bob Kurgan's
1987 Mustang Coupe 5.0 - Going through 5.8L build.
GodStang is offline
post #2 of 8 Old 09-10-2013, 12:56 PM
Decipha's Avatar
there's plenty megasquirt, aem, big stuff, fast, etc.. that people are using its just up to what you plan on doing and what your goals are as well as your budget
a stock mass air ecu from an 89+ foxbody preferably 94-95 mustang can be had cheap from a u-pull it, would be your cheapest and fastest route to go, and if it ever goes bad its only $100 to replace at any autozone
that does require you to learn how the ford ecu's functions though if you want to tune it yourself or just get a base tune done so its all dialed in then all you have to do is put in what ever AFR want you what ever spark advance you want, doesn't get any simpler than that, all the info you need can be found here
Index / Ford / EFIDynoTuning
decipha @ EFIDynoTuning
www.efidynotuning.com
Decipha is offline
post #3 of 8 Old 10-09-2013, 08:33 PM
I have my eye on a unit from Pro M racing. Promracing.com - The Standard of Mass Air Meters!
SOLD
86GT
Kuntz&Co. 306
RPM heads/intake
Demon 650
ZT-5
3.55's
Best time this year:
1.87 60ft
5.16 in 330ft
7.948 @ 89.96in 1/8th
10.151 @102.85in 1000ft
Best 60ft on DRs 1.79
Best 1/8th MPH 90.94
Best MPH on DRs 103.78
Maybe I'll buy an SVO to replace the 86 GT.
Thebeast is offline
post #4 of 8 Old 10-09-2013, 09:35 PM
knuckl-head's Avatar
Trader Feedback: (18)
I'm running a FAST XFI that I bought used and have about $1,000 or so in it and really like it. Its fairly easy to tune and I don't have to worry about a mass air meter anymore. But if I was to buy a new unit it would be a new Holley Dominator. Probably hands down the best on the market right now IOM.
Sent from AutoGuide.com App
65 mustang 12.16 @ 111 mph 1.85'
349ci, 185 AFR heads, Systemax intake, custom FTI cam, & 275/50/15 Nitto radial.
knuckl-head is offline
post #5 of 8 Old 10-10-2013, 10:13 AM
The first question when selecting an EFI system is what features you'll need. Fuel and ignition control are the usual ones, but think of anything you might have a black box controller for, and it may be possible to run it through the EFI system.
Matt Cramer
Matt Cramer is offline
post #6 of 8 Old 10-13-2013, 08:36 PM
MSCHLITZKUS's Avatar
Best EFI
Holley Dominator with self learn is the way go and the latest out. Run a couple grand with v8 harness. Can get the Holley HP for around $1500 and does same less features but good for street car.
MSCHLITZKUS is offline
post #7 of 8 Old 10-13-2013, 09:53 PM
89BlackGtVert's Avatar
You can spend half the amount of the big guys on a Megasquirt and have everything they have including self tuning. I am installing one in my current build.
1989 GT Vert.. Major Changes for 2013 Wish me luck
Old setup from 2012 On3 Turbo, Trick Flow 170 Heads, Edelbrock RPM upper & Lower, Trick Flow Stg 2 cam, UPR K-member and control arms and Strang front and rear coil over, and UPR upper and lower rear control arms, MM frame connectors Fully Built AOD, 512whp
89BlackGtVert is offline
post #8 of 8 Old 10-16-2013, 06:33 PM
wytwolf's Avatar
Megasquirt. Unless you got money to burn, then Haltech.
wytwolf is offline
For Sale 1993 Mustang LX Coupe 408 efi RacingJunk Mustangs For Sale/Wanted, 1987-1993 8 11-22-2012 05:01 PM
Want To Buy need a 92 5.0 EFI engine harness for a coupe 5.0 racer Electronics and Entertainment 1 10-21-2012 08:21 PM
For Sale Wanted: Fox Body LX coupe high hp EFI streetcar STREETPOWER EFI 331 Mustangs For Sale/Wanted, 1987-1993 23 10-02-2012 08:09 AM
For Sale 1993 Mustang Lx coupe 408 efi Sprayed_347_Coupe Mustangs For Sale/Wanted, 1987-1993 3 12-06-2011 07:29 PM
For Sale 1993 Mustang Lx Coupe 408 EFI Sprayed_347_Coupe Mustangs For Sale/Wanted, 1987-1993 1 09-21-2011 09:15 AM
