Help ! Fuel pump won't kick on - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-27-2013, 10:49 PM Thread Starter
Question Help ! Fuel pump won't kick on
I have an 87 GT and the fuel pump will not turn on unless i bypass the relay at the relay plug. I've tried 3 different new relays. I have constant 12 volt signal at the relay plug. I also have switched 12 volt at the plug. If i bypass the relay with a jumper wire at the plug with either the constant 12 volt or switched 12 volt poles, the pump runs fine and continuously. Any ideas ? Thanks !!!
lofreqq is offline
post #2 of 3 Old 08-28-2013, 09:20 PM
Flyin Ryan's Avatar
Trader Feedback: (38)
PCM
I just went through this with both my foxes.. one wouldn't prime while the other was stuck constantly priming. Remanfactured a9l fixed both cars
Originally Posted by blue93hatch View Post
I spec'd my whole build to fit a cold air intake I had
Flyin Ryan is offline
post #3 of 3 Old 08-30-2013, 11:38 PM
First, check these components of piping, gasoline, nozzle whether they are going smoothly. Second, check are there any places broken of the fuel pump line in each corner.
William Gerada is offline
Fueling a 500 RWHP supercharged fox? BIGRIGS Superchargers 21 05-19-2013 04:44 AM
Bosch fuel pump overheated? 89WhiteGTRagtop General Mustang Tech 11 07-27-2012 03:38 PM
Fuel pump / sending unit question Super-G General Mustang Tech 6 03-12-2011 11:47 PM
Walbro GSS340 Fuel Pump Install a50sn95 General Mustang Tech 0 12-14-2001 09:06 PM
