HELP! engine cuting out - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 08-12-2013, 07:23 AM Thread Starter
hi I've been having problems with my 02 GT cutting out for quite a few months now hoping for some suggestions or that someone had the same problem when I get up around 3-3500 rpm the engine cuts out like it hits the rev limiter
originally the codes that came up it said #2 open injector circuit and not enough fuel pressure along with random misfire I checked the wiring harness to the injector all the proper readings so I swapped out the injectors for larger ones and put a 255 fuel pump in it took her out for a run and it still dose it so I took the accel high output coils out and put the old ones in and the problem appeared to be fixed until the car warmed up and then it started acting up again but not as bad I think its a big clue to what might be wrong I also tried to read the codes despite the lack of the check engine light and no codes show up
02silverbullet is offline
Pro-M EFI Engine Management System Michael Plummer Superchargers 563 04-03-2017 08:18 PM
4.6 DOHC question. Rfreeman37 SVT & DOHC 313 01-07-2014 10:35 PM
1989 mustang gt randomly shuts off five.zero General Mustang Tech 5 04-10-2013 10:49 PM
For Sale Engine for sale-Ford 302(306), X303 Cam, TFS 170 Heads-Manassas, VA rfturner5773 Windsor Engine Parts 0 03-04-2013 10:36 AM
Help Wanted! PLEASE Read. (BLOWER CAMS) MARK 302 Superchargers 53 02-24-2012 09:51 PM
