Wideband O2 monitor and recorder - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 08-08-2013, 12:44 PM Thread Starter
TomR's Avatar
Let me reword this a little. Maybe since my LM2 is not working, I should just get a multi-channel recorder? Is there something available that gives an alarm, and records multiple channels? Most important, that is reliable?
I have a LM 2 Innovate that has been a bit buggy since new. The suggested reloading it with a different computer, but that didn't work. I tried reloading firmware, but it hangs at 90% on the verification test.
Are there more reliable, better supported, units? Or should I just try buying another new LM 2 Innovate?
I only use it for data logging my mixture vs RPM, just so I can tune. Is there something better??
TomR is offline
post #2 of 6 Old 08-09-2013, 09:05 AM
They won't warranty it? That's what I'd be pushing for.
Megasquirt
seijirou is offline
post #3 of 6 Old 08-12-2013, 01:15 AM
toyman's Avatar
Don LaSota (Lasota Racing) recommended that I use the Zeitronix system. It has worked flawlessly for me for the past 8-9 years.
Richard
KB 2.1L @ 9psi, FRPP M5400-A Suspension System, FRPP Aluminum D/S, Built AODE and TC, FRPP 3.73 Gears, Balanced Roller Cammed Engine, Edelbrock Performer Heads, Comp 270AH cam, AEM EMS, 3.5 Bar MAP, Zeitronix ZT-2 WB, FRPP 70mm TB, modified UPR CAI, Be Cool Aluminum Rad
toyman is offline
post #4 of 6 Old 08-22-2013, 05:31 PM
fox88's Avatar
He said the same for me also.
fox88 is offline
post #5 of 6 Old 08-26-2013, 09:33 AM
Banned
What system are you tuning with?
post #6 of 6 Old 08-26-2013, 11:49 AM
My LM-2 works great , have you tried seeing if you can get a RMA# from Innovate to send it in to have checked out
93GRNLX is offline
