Can't pull codes on 89 GT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-08-2013, 11:26 AM Thread Starter
Hey guys, I have a problem pulling my check engine codes from my 89 GT. I pu the jumper wire in the connector and when I start the car, the light simply refuses to blink. I have pulled the codes before successfully, but now they won't come out. I know I am doing everything correct because I've done it before, so is there a fuse or something the could have blown?
foxbodyfellow is offline
post #2 of 3 Old 07-14-2016, 07:16 AM
I have the same problem with my 95, mine ruins ok when cold but once it warms up it runs bad, I can't get the check engine light to go on at all and when I tried a scanner I got a connection error, I tried with a paper clip at the self test plug and still could get no codes. The bulb on the check engine light is ok because I got it to blink when I used the paper clip, I got around 7 or 8 single flashes the a 176 code. Does this look like a computer problem to you guys? Also the guages on the dash are acting up.
ogieruiz is offline
post #3 of 3 Old 07-17-2016, 10:21 AM
indy2000's Avatar
check 5v ref circuit
no comm
can be from issues on 5v ref circuit, or faulty ecm
in crank does the check engine light, go out?
in a ford, when you put the key in run, you get the prime and a bulb check, the CEL, should remain on, until you crank, in crank it should go out.
indy2000 is offline
Got a new shipping scale and started weighing items, T5, stock hood, fender, heads Speeds8erM-1 General Mustang Tech 107 04-08-2013 05:48 PM
For Sale Misc fox body parts n8secstangg Miscellaneous Mustang Parts 3 12-04-2012 06:42 PM
For Sale Misc fox body parts n8secstangg Windsor Engine Parts 0 11-01-2012 07:35 PM
Behind the Smoke with Dai Yoshihara - The Series Discount Tire Discount Tire 24 11-03-2011 04:50 PM
Lease or buy a 2012 GT (since 2014 GT is supposed to be different.....) 02WhiteGT S-197 Mustang GT (2011-2014) 16 05-16-2011 11:06 AM
