Rpm question for tune... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-13-2013, 07:11 AM Thread Starter
Madspeed's Avatar
Have a single turbo setup on my 89. Tuning with a Moates Quarterhorse. I have the rev limiter in the tune set to 5800 and 5600 on my Summit branded ignition. Got me thinking, in trying to keep her under 6000 rpms to prolong the stock block, which one do i want set lower than the other? Doesnt the eec kill fuel and the ignition would kill spark, so i would set to kill spark first correct?
Sent from my wealth of useless knowledge!
Shameless plug.... My Business
Use coupon code MADSPEED for a 20% discount!!
Madspeed is offline
post #2 of 4 Old 06-13-2013, 07:23 AM
89BlackGtVert's Avatar
I don't know how the chip handles it. But if it does it the same way the stock ecu does. Then hell yes use the box. Because it will use spark no fuel, and won't lean you out.
Sent from my PI86100 using Board Express
1989 GT Vert.. Major Changes for 2013 Wish me luck
Old setup from 2012 On3 Turbo, Trick Flow 170 Heads, Edelbrock RPM upper & Lower, Trick Flow Stg 2 cam, UPR K-member and control arms and Strang front and rear coil over, and UPR upper and lower rear control arms, MM frame connectors Fully Built AOD, 512whp
89BlackGtVert is offline
post #3 of 4 Old 06-26-2013, 01:39 PM
The mixture doesn't lean out; there is no mixture. When an injection event is cut, there is simply no fuel for that cylinder to burn. OEMs use it almost exclusively, if not exclusively, even with turbo engines, because it doesn't have the same potential for damaging parts that spark-only rev limiting does. Throwing fuel and air into the exhaust sets up the potential for melted cat converters (if you have them) and/or lighting off ahead of the turbo, which will put tremendous thermal stress on both it and the piping. Great for boost, bad for parts.
There is the issue of wall wetting and fuel cut will cause the ports to dry out, which has bearing on how the engine responds when fuel comes back. I am not sure how the EEC-IV strategy handles that.
1968 Mustang notchback-H/C/I/E/etc.
1972 Pinto Runabout-2.3T/T5/MS-II.
GT Madness is offline
post #4 of 4 Old 07-14-2013, 01:39 AM
Decipha's Avatar
it fires every other injector to prevent the engine from wrapping, its not as effective as killing spark then thats a dead limiter, but it works very well, i usually recommend using both a spark and fuel limiter, just set the fuel limiter at the same rpm as your ignition box limiter
decipha @ EFIDynoTuning
www.efidynotuning.com
Decipha is offline
What rpms should I be launching and shifting at? JOHNNY HORSEPOWER Drag Racing 8 02-24-2013 01:54 PM
Help Wanted! PLEASE Read. (BLOWER CAMS) MARK 302 Superchargers 53 02-24-2012 09:51 PM
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
spin tech mufflers rkloehn General Mustang Tech 27 07-01-2011 12:06 PM
I'm getting old... blacksnake305 SVT & DOHC 14 05-16-2011 10:13 AM
