Laptop Computer choice? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 06-03-2013, 08:05 AM Thread Starter
TomR's Avatar
Any problems with Windoze 7 or 8 and programs like Tweecer, Cal Edit, BE, or BA?????
Anything special I should look for in a new "car only" computer??
TomR is offline
post #2 of 15 Old 06-09-2013, 11:41 PM
indy2000's Avatar
any new LT will work with those OS.
I prefer the smaller ones, less cumbersome.
indy2000 is online now
post #3 of 15 Old 06-12-2013, 10:57 AM
Please call me Mike
mr_minnis's Avatar
Trader Feedback: (46)
-agreed
make sure it has decent size battery and/or a dc charger.
try to find one with the usb ports on both left and right sides
personally i would want one with a serial port, finding a new one with that is hard
84K 88 LX Vert 5spd: 3.73s.
mr_minnis is offline
post #4 of 15 Old 07-12-2013, 08:18 AM
I bought a cheap, cheap, Toshiba kids model computer from Bestbuy. Has disk drive, plenty of USB, Serial Port and a spill proof key board. Being a kids computer, it has extra shock protection for when it falls off the fenders while the car is running, etc. The spill proof key board is nice to not have to worry about grungy fingers when working on the car and using the laptop at the same time.
kbscobravert is offline
post #5 of 15 Old 07-12-2013, 08:46 AM
Nice I might have to check that out. I have an ancient and large dell and it's getting obnoxious.
Megasquirt
seijirou is offline
post #6 of 15 Old 07-14-2013, 01:37 AM
Decipha's Avatar
i used to have a little acer netbook, one day it crapped out on me and i had to get a new laptop, i currently have a gateway with a 19" screen this thing is massive, i very much dislike this large of a laptop
i highly recommend getting a small laptop or a netbook, at least 3 usb ports is a minimum requirement, i wish i would have gotten another netbook and i will eventually
getting a laptop with a back lit keyboard is a major plus as well
if your using binary editor i recommend getting an intel based laptop, the amd's and what not don't work so well with some direct flashing hardware
if you do want large, the alienware laptop are very nice!!!
decipha @ EFIDynoTuning
www.efidynotuning.com
Decipha is offline
post #7 of 15 Old 08-03-2013, 11:25 AM
Just Chuck's Avatar
If you get a windows 8 machine, you might have to disable the strict driver signing since I know the tweecer isn't MSFT certified and I doubt the quarter horse would be either.
1989 LX 5.0 - 333 Mexican block, Eagle 4340 neutral3.25" crank, Probe SRS 9cc dome .040 psitons AFR 185 Comp heads, FTI HR cam 239/244 613/613, Edelbrock Victor 5.0, 90mm TB, BBK 1 3/4, C4 and 4500 Circle D converter, 4.10 gears
2012 GT/CS 5.0 - Yellow Blaze Tri-Coat metalic, A6, HID.
Just Chuck is offline
post #8 of 15 Old 08-12-2013, 01:24 AM
toyman's Avatar
If you are buying new find one with a daylight screen. I find that on bright sunny days it's hard to see the screen content with the laptop on the passenger seat.
Richard
KB 2.1L @ 9psi, FRPP M5400-A Suspension System, FRPP Aluminum D/S, Built AODE and TC, FRPP 3.73 Gears, Balanced Roller Cammed Engine, Edelbrock Performer Heads, Comp 270AH cam, AEM EMS, 3.5 Bar MAP, Zeitronix ZT-2 WB, FRPP 70mm TB, modified UPR CAI, Be Cool Aluminum Rad
toyman is offline
post #9 of 15 Old 08-28-2013, 10:53 PM
Flyin Ryan's Avatar
Trader Feedback: (38)
I have a few Thinkpads I am not using that i'd sell for a good price. They are solid machines and worked great for tuning my gmc syclone and typhoon. PM if interested and i'll dig up the specs. I believe they are T410 and T420 models.
Originally Posted by blue93hatch View Post
I spec'd my whole build to fit a cold air intake I had
Flyin Ryan is offline
post #10 of 15 Old 10-22-2013, 12:06 AM
Indo-Canuck-Yankee
Shaker666's Avatar
+1 on the backlit keyboard. I could really use it!
I use a tiny little netbook: HP Mini 210. It's got 3 USB ports on it, has an Intel Atom processor so it has insane battery life, and with an SSD and SD card, it's a reliable little tuning and datalogging machine. Best of all... it was free! Courtesy of those rewards points you earn through credit cards.
I run Windows 7 32-bit just for compatibility sake. I don't do much else with the netbook, it's pretty much a BE and TunerPro RT field computer.
'71 Mach 1: totaled - R.I.P.
Shaker666 is offline
post #11 of 15 Old 10-22-2013, 11:24 PM Thread Starter
TomR's Avatar
Thanks....I wound up with a IBM Thinkpad using a solid state drive. It has LONG battery life and the SS drive makes it fast and vibration proof. I had to completely remove the ThinkPad OS and installed Windows XP Pro as the only OS.
Tweecer CalCon and CalEdit would not run on the ThinkPad OS, but straightened right out with XP.
TomR is offline
post #12 of 15 Old 10-23-2013, 10:48 AM
Flyin Ryan's Avatar
FYI XP kills solid stat drives..
post #13 of 15 Old 10-23-2013, 11:50 AM
Indo-Canuck-Yankee
Shaker666's Avatar
Yes, that's true. XP is so old that it predates TRIM function and other SSD specific things.
I run Windows 7 and haven't had any problems with any software, whatsoever. Windows 7 might be the best OS that Microsoft ever made!
post #14 of 15 Old 10-24-2013, 07:10 PM Thread Starter
TomR's Avatar
SS drives don't care what OS is on them. That rumor
comes from early SSD's, where the drives themselves were unreliable.
Then, as SS drives improved and MTBF increased, operating systems also changed.
The result of this is people think it was the OS change, when it actually was drive quality improving.
TomR is offline
post #15 of 15 Old 10-24-2013, 07:16 PM
Indo-Canuck-Yankee
Shaker666's Avatar
You're right, SSD's don't care about what OS is reading/writing to them. However, flash NANDs have a finite number of write cycles. If the OS doesn't explicitly deal with this limitation, it's up to the NAND controller to deal with it instead. And most NAND controllers aren't that sophisticated. Sandforce and Intel controllers are pretty decent, but it's still up to the OS to optimize SSD performance and lifetime.
1989 mustang gt randomly shuts off five.zero General Mustang Tech 5 04-10-2013 10:49 PM
Want To Trade Computer parts, laptop or web design for car stuff 89BlackGtVert Windsor Engine Parts 5 08-11-2012 08:12 PM
On3 has done it again...... 2Guard Turbochargers 179 08-13-2011 03:29 AM
Abbott and Costello, selling a computer Streetstrip01 Lounge 2 03-10-2011 09:08 PM
