BE/EA how to setup to read my PLX afr? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 05-23-2013, 10:32 AM Thread Starter
Madspeed's Avatar
Just got my turbo install finished and registered the Binary Editor along with the EEC Analyzer and a Moates Quarterhorse. I understand how to wire up the PLX AFR gauge to the EGR #27 pin on my A9L, but how to I properly setup Binary Editor and Eec Analyzer to read it? Man this computer tech stuff is making my head swirl!!
Shameless plug.... My Business
Use coupon code MADSPEED for a 20% discount!!
Madspeed is offline
post #2 of 11 Old 05-23-2013, 07:48 PM
liljoe07's Avatar
Trader Feedback: (18)
Which version of BE do you have?
89 Coupe: POS
Tuner: QuarterHorse, BE & EA, AEM Wideband
liljoe07 is offline
post #3 of 11 Old 05-23-2013, 08:07 PM Thread Starter
Madspeed's Avatar
latest 2012, just downloaded last week. If I go into the hardware tab, I check the box to enable the PLX, but no clue from there
Madspeed is offline
post #4 of 11 Old 05-23-2013, 08:08 PM
quickerstang's Avatar
not 100% sure, but I had to buy the innovate "add on" and the dataQ" one also
quickerstang is offline
post #5 of 11 Old 05-23-2013, 08:18 PM Thread Starter
Madspeed's Avatar
when I bought the Binary Editor registration, ou can pick one optional datalogger liks Inovate, PLX, AEM, etc. I picked the PLX, iyt appears as an option I can choose, but just cant find any clue how to properly set it!
Madspeed is offline
post #6 of 11 Old 05-23-2013, 08:44 PM
liljoe07's Avatar
That's not required when using the EVP circuit. Matter of fact, if using the EVP circuit, you don't even have to purchase an optional logger.
Go to hardware and click the transfer function box. Make sure its labeled AFR. Input the PLX transfer function. Then exit the hardware section. Go to the data logging in BE and make sure EVP is checked. In the dash board, you need to right click over a guage the hit config. Choose the correct TAG and name it AFR as well.
Try that and see how it goes. I have 2010, but the are real similar in layout.
89 Coupe: POS
liljoe07 is offline
post #7 of 11 Old 05-23-2013, 08:49 PM
liljoe07's Avatar
Also, if there is no drop down box in the hardware section under transfer function. There should be a check box, make sure its checked, and on that one, just type in AFR and BE will know what do with it. Still have to enter the PLX transfer function though.
89 Coupe: POS
liljoe07 is offline
post #8 of 11 Old 05-23-2013, 08:50 PM Thread Starter
Madspeed's Avatar
Ok, I'll check that out tomorrow. I did hit thetransfer function and change the tag name from EVP to AFR, but I'll have to look at it again as I didn't see anthwhere to change the unit of measure fom volts or a place to input the PLX transfer function numbers
Madspeed is offline
post #9 of 11 Old 05-23-2013, 09:54 PM
liljoe07's Avatar
EECTuning.org • View topic - Logging AFR through EVP
Should look like this....
89 Coupe: POS
liljoe07 is offline
post #10 of 11 Old 05-27-2013, 11:42 AM Thread Starter
Madspeed's Avatar
still having issues. Im on build 23 and its a bit different than the older builds ive seen screenshots of. I still cannot locate any place to enter the transfer function. On the hardware tab there is a PLX box, if I enable that and go into the config there four boxes, Label, Type, Units, Instance, but no place to input the xfer function. Maybe its built in to the programming once i enable the PLX in hardware, but i,ve no clue what to select as far as the values in those four boxes. Ive sent Clint an email through tech support hoping for sme help.
Madspeed is offline
post #11 of 11 Old 05-27-2013, 10:19 PM Thread Starter
Madspeed's Avatar
figured it out, thanks for chiming in fellas!
Madspeed is offline
For Sale TURN-KEY TURBO BIG BORE 347 DSS AFR 614 RWHP/657 RWTQ bikewiz Windsor Engine Parts 11 03-26-2011 09:21 PM
Want To Trade wtt dynamic pro tree2 powerglide setup for built c4 or aod setup fuzz Drivetrain Parts 0 03-01-2011 06:14 PM
AFR on the spray Diabolic Nitrous 4 02-22-2011 01:42 PM
For Sale Complete dual Front Mount A/w Setup with 5 gal Tank and Lines Blown302stng Power Adders 12 12-31-2010 08:35 AM
More gains. Only AFR 165 or complete GT40 setup 5ptgo 5.0/5.8 Engine Tech 32 01-09-2002 03:28 PM
