rolling idle - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-21-2013, 09:32 AM Thread Starter
rolling idle
alright just got the car running again and I am having a rolling idle aways did and I am sick of it need it fixed so the wife can drive it. I tune with a old EPEC. No matter where I set the A/F it still does it I have moved the timing around up and down no help. Now when it is in gear the roll is very low but throw it in park or N and there it is. It is not the IAC the epec don't look at that it is not the o2s it don't look at them either. One thing I did do last night is pulled the spout out and wham it idled like a dream. I am not looking for this thing to idle at 700 rpms or anything like that so I am not asking that of it. 1000 to 1100 is okay.
I am sure it is in my tune but I am trying to save some time and gas with this so looking for some help with it.
I drilled a hole in the T/B last night to help and it seems to have a bit but still not the answer. What has got me is pulling the spout and it sets there and idles great (after I drilled the hole in the T/B). There is a area in the EPEC where you can go in and shut off the timing control and it is the same thing idles great. This makes me think it is a timing issue. DUH
I guess I need to log it and see if the EPEC will still control the spark with the spout out but I don't think it will.
Run down on the car 306 83# injector Holley intake PMAS blow through meter TFS heads, turbo cam and a turbo. blah blah blah you know just a street turbo set up. and yes the EPEC has a driver for the big injectors.
Turbo 306,How fast will it go that depends on who is around.. Local parts pimp.. Things for sale most stuff is OBO https://docs.google.com/document/d/1hvqaA8aKICIw6BBj3IU2KCwiv86TtWXmxmvrsd8lw1A/edit?hl=en_US&pli=1#
wvstangdriver is offline
post #2 of 5 Old 05-21-2013, 12:10 PM
wytwolf's Avatar
Sounds like its idling between different timing values. Not familiar with EPEC tuning, but check timing tables. Pulling the spout, as I'm sure you know, just locks the timing at base. In, it will use the table. Change timing around where it idles to all the same and probably will settle right down. Just my .02.
wytwolf is offline
post #3 of 5 Old 05-21-2013, 02:03 PM Thread Starter
Thanks will give it a look.
post #4 of 5 Old 05-23-2013, 06:23 PM
Yeah if pulling the spout works you likely can solve this by pulling timing out of the idle areas. That's the same difference as pulling the spout.
Megasquirt
seijirou is offline
post #5 of 5 Old 05-28-2013, 08:06 AM
TomR's Avatar
I had that problem and had to re-curve the timing in the spark tables related to idle, so the idle speed was not on the slope of a big timing change. Flatten the spark tables out with good advance at idle, but no advance at cranking.
TomR is offline
Does a hole have to be drilled in TB blade to set idle? from6to8 94/95 Tech 86 05-20-2014 07:57 AM
Rolling idle. Just installed procharger and lethal performance fuel system Baad2003Mach1 SVT & DOHC 7 05-10-2013 01:52 AM
Tuning idle to drive transitions. 92rohcp MegaSquirt DIYAutotune Systems 7 05-06-2013 11:10 AM
Reset the TPS if adjust idle...................... from6to8 94/95 Tech 6 07-23-2012 05:06 PM
rolling idle and code 67 IVE RESEARCHED! quickcoupe 5.0/5.8 Engine Tech 6 02-24-2011 06:47 PM
