Holley Hp User needs help!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-05-2013, 12:27 PM Thread Starter
tubbedstangeater's Avatar
Okay I got a day off from work this sunday here in ohio. Nice day out to finish the hp efi installation. I transistioned from a c950 efi setup just recently so im pretty stoked to check out this autotune stuff. So I go to sync the 302 turbo configuration with the ecu and it gives me errors.
ecu rtc timed out along with everything timed out when in sync process. It installed the software on xp but for some reason the driver for the usb attachment i think isnt working? It also is throwing communication errors.
336ci, twin 66 turbo, diamond 9.5cr pistons, boss block, eagle forged crank ,80mm accufab,bullet cam, Msd 6al, Holley Hp wideband system, trick flow box r intake, front mount, 3400lbs, 3200 stall, c4 transmission, 06gt, best 1/4 9.876 135.75 1.41 60ft , A1000 pump,80lb injector
tubbedstangeater is offline
post #2 of 2 Old 05-06-2013, 12:37 AM
wytwolf's Avatar
Using the serial to USB adapter? If the drivers aren't loaded properly, it'll cause comm problems.
wytwolf is offline
For Sale Holley HP Efi, Holley Dominator Fuel Pump xssive Fuel System & Related 14 09-03-2013 02:32 AM
For Sale Holley 750cfm 4160 Dual Feed Polished Carb - Fuel Rail - Russell Fuel Pressure Gauge NeoTokyo Fuel System & Related 8 10-18-2012 01:08 PM
Anyone running a Holley Billet Fuel Pump? TxFireman1972 5.0/5.8 Engine Tech 2 05-25-2012 09:54 PM
World Junior vs Holley Systemax Heads Wicked03GT 5.0/5.8 Engine Tech 7 09-09-2011 07:08 PM
