Pleasw help!!! tps green wire reading 5 volts at closed throttle - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-08-2013, 08:16 PM Thread Starter
blck04cobra's Avatar
Please help!!! tps green wire reading 5 volts at closed throttle
Went to the dyno and there was an issue.. The green wire on the tps was reading 5volts at closed throttle. Help!!!!!!!! Its a 93 coupe. Help help please.....new tps and ecm..
blck04cobra is offline
post #2 of 4 Old 04-09-2013, 11:37 AM
Unbolt the TPS and then check it again.
Megasquirt
seijirou is offline
post #3 of 4 Old 04-09-2013, 11:56 AM Thread Starter
tps
I've checked it unplugged and plugged.. I've checked it at the harness..
post #4 of 4 Old 04-09-2013, 12:04 PM
verify continuity between that wire at the TPS plug and the correct pin on the ECU plug.. it sounds like it's crossed somewhere.
do you have 5v on both wires?
Megasquirt
seijirou is offline
Tags
short, tps
1989 mustang gt randomly shuts off five.zero General Mustang Tech 5 04-10-2013 10:49 PM
Car shut down while driving and will not restart, HELP! shdowconspiracyx 5.0/5.8 Engine Tech 15 09-10-2012 02:31 PM
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
Strange TPS Problem LeaningMachine 5.0/5.8 Engine Tech 0 01-24-2012 12:10 PM
