X3Z Problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 04-02-2013, 07:13 AM Thread Starter
tyler97's Avatar
Trader Feedback: (31)
X3Z Problems
is it common for them to do,, If I floor the car from idle it studders real bad and eventually goes up, could this be the eec, does the maf have to be clocked it is sideways now, could it be the cheap streetfire(MSD) Coil? any help is appreciated.
306 unported gt40s, unported cobra intake, Stock Cam...
F/S
tyler97 is offline
post #2 of 7 Old 04-04-2013, 03:12 AM
wytwolf's Avatar
Try replacing the TFI module on the distributor. Common for these cars.
wytwolf is offline
post #3 of 7 Old 04-04-2013, 10:45 AM Thread Starter
tyler97's Avatar
i did that 3 times, think it could be bad from the factory?
F/S
tyler97 is offline
post #4 of 7 Old 04-04-2013, 02:08 PM
wytwolf's Avatar
Stock cam and everything?
wytwolf is offline
post #5 of 7 Old 04-04-2013, 02:37 PM Thread Starter
tyler97's Avatar
TFS 2
F/S
tyler97 is offline
post #6 of 7 Old 04-05-2013, 11:43 PM
wytwolf's Avatar
Of course, if I could read, I'd see that in your sig. Stick/auto? What rear gears? Has it been tuned at all? I've always had my MAF straight up(electronics on top). THEORETICALLY, it shouldn't matter, but you can play with it. Other than that, check your timing. Initial, then get someone to help you out and rev it up a bit and make sure it's advancing properly. If it lags a bit, then picks up, sounds like timing.
wytwolf is offline
post #7 of 7 Old 04-06-2013, 06:55 PM Thread Starter
tyler97's Avatar
I'm going to try a a9p and moates, but 355 and stick
F/S
tyler97 is offline
X3Z, A9P question..... vinnietbird General Mustang Tech 6 05-07-2012 02:06 PM
99 Cobra Problems..Help me help a friend 91GTturbo SVT & DOHC 10 10-04-2011 02:00 PM
Arrrrrr! More electrical problems! Lisa GT & SOHC 11 06-05-2004 05:59 AM
DOHC engine failures & problems... Cobra Jet NJ GT & SOHC 30 12-07-2001 12:43 PM
Has anyone else had problems with Aeromotive fuel pumps? 99redsnake General Mustang Tech 19 12-07-2001 06:28 AM
