Need help with QH and BE - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-23-2013, 07:47 PM Thread Starter
EscortSportage's Avatar
My car is running super rich! And drinking gas i need to lean her out how can i do this on binary editor?
Im using 42lb injectors with a 3inch pmas maf sensor
Shes a H/C/I car
1. Shes running super cold
2. Shes chugging till i get on her (which i hear is a symptom of running rich)
3. I smells gas while inside the car
4. And im at the gas station more than on the road
Its just a 302. I dont remember her being so bad on mileage which i want to start keeping a track of to actually find out the mpg im getting
I kind of want to get rid of these 42lb injectors but if i can keep them and turn them down some it might work.
Time Attack Fox
instagram.com/escortsportage
EscortSportage is offline
post #2 of 4 Old 02-23-2013, 11:03 PM
RBELL's Avatar
Trader Feedback: (21)
You realy should let someone else tune the car, it's a lot harder than you would think. The bigger the injector the more that needs to be done to the tune to make the car work correctly. 42s are big enough to need quite a bit of work done to the tune, it also sounds like your car has other things that need to be fixed before starting to tune it. If it is running cold, you need to figure out why and fix it, like put an new thermostat in it for starters.
If I buy a part or parts from you do not send me those parts through USPS, I would actualy like to get the parts I purchase.
RBELL is offline
post #3 of 4 Old 02-24-2013, 02:36 PM Thread Starter
Im running a 180 thermostat, i put in last year,
I will see how she runs when it gets warmer out,
I have to get her on the rollers cuz this cant be right
Time Attack Fox
post #4 of 4 Old 03-01-2013, 10:41 PM
Banned
Are you using a specifically calibrated MAF? Did you change the scalars for your injectors?
Would you mind e-mailing me your current map so I can take a peek at it?
