If you was straing from scratch, which would you use? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 12-17-2012, 01:54 AM Thread Starter
Wicked03GT's Avatar
Trader Feedback: (50)
If you was starting from scratch, which would you use?
I literally mean from sratch....Motor and car are as bare as they come in terms of any EFI to plug into being in place. I have a 6AL ignition box and thats about it...
357w, 10.62:1, Hyd. roller custom grind, 5 speed, 3:72 gears...Just a fun street car that I want to be reliable and fun to drive. Doesnt have to set any records, or make insane power.
Wicked03GT is offline
post #2 of 8 Old 12-17-2012, 11:26 AM
I was in the situation you describe with my 393w. I got the car as a project with the longblock assembled but never run. After chasing down all the missing pieces and installing the engine in the car I spent a couple of weeks figuring out what all my EFI options were and settled on megasquirt.
MS is the only computer the engine has ever run on and I can say I have no regrets and now being on the other side of the choice, I would choose MS again.
Megasquirt
seijirou is offline
post #3 of 8 Old 12-20-2012, 08:53 AM Thread Starter
Wicked03GT's Avatar
What did you use for all the different harness' for things such as the MAF, injectors and computer?
post #4 of 8 Old 12-20-2012, 10:16 AM
Megasquirt can use a MAF but it is not necessary and I chose not to use one. My install runs in Speed Density mode using a MAP sensor to read engine vacuum/boost (however I am not boosted).
I am using the factory engine harness, which gives me coolant temp, air temp, injectors, TPS, high and low speed fans, wiring to the TFI module and coil, and factory oxygen sensors.
If you're willing to spend a little more money, DIYAutotune.com sells adapter harnesses to make connecting Megasquirt to the factory harness an easy plug-in process.
Even easier yet (and more money too), they sell a plug-and-play version of Megasquirt that plugs in to the factory harness just like the factory computer does. I think their PNP setup has the same physical dimensions as the factory computer too.
Of course if you wanted you could pull out the factory harness and wire everything yourself.
Megasquirt
seijirou is offline
post #5 of 8 Old 12-20-2012, 08:32 PM
I'm in the same boat and I'm going MS.
diyautotune.com also has a harnass adaptor like this:
Megasquirt V3.0/3.57 to Ford Mustang 5.0 Adapter Cable DIYAutoTune.com
They have it for SN95 5.0 and MS2 configurations. That is most likely how I'm going, using a stock harnass I have and going with the adaptor. That, or I'll go with the relay board and just cut the stock harnass plug off and use the relay board.
MegaSquirt Relay Board - Assembled Unit DIYAutoTune.com
That way I can avoid making my own set of relays for the fuel pump and stuff. See, my car really is a blank slate for EFI since it's a 65 mustang.
Recycle: Buy a classic Mustang
1965 Mustang Convertible 'KaStang'
BigJimSlade is offline
post #6 of 8 Old 12-20-2012, 11:56 PM Thread Starter
Wicked03GT's Avatar
Mine might as well be a blank slate...All the EFI stuff is cut out of it, its bare bones on the wiring to a simple fuse box for the headlight switch, ignition, fuel pump, lighting, and fan switch.
I think im venturing out of my skill set for this though...Been pricing out fox EFI harness stuff and its pretty cheap, but there are a couple different versions not too mention I dont know if im buying a junk harness or not.
post #7 of 8 Old 12-21-2012, 12:37 AM
Not sure if you mean megasquirt versions or engine harness versions. If you mean MS here is some info to help sort out what is what. Megasquirt Identification - What Megasquirt do I have?
If you're worried about harnesses, I can vouch for the ones that diyautotune sells. It's quality stuff. You'll need to run the wires to the sensors and injectors and things yourself but that's not necessarily a bad thing.
Megasquirt
seijirou is offline
post #8 of 8 Old 12-21-2012, 12:21 PM Thread Starter
Wicked03GT's Avatar
I was referring to the used harness' on sites like Ebay and craigslist...
Hooking up my EFI from scratch..... GRFox 5.0/5.8 Engine Tech 9 06-10-2012 10:20 PM
scratch in bore thinking of gt40 heads and intake on a 347 Chris81579 5.0/5.8 Engine Tech 3 11-16-2011 12:34 AM
scratch on cylinder heads 93reefblue 5.0/5.8 Engine Tech 15 03-29-2011 09:53 PM
Build from scratch or not? 2VSouth SVT & DOHC 3 02-28-2011 11:45 PM
Scratch in cylinder opinions mustang86super 5.0/5.8 Engine Tech 10 11-16-2010 08:27 PM
