SCT Red Light No Start.. HELP - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-05-2012, 09:19 PM Thread Starter
89BlackGtVert's Avatar
Hello, everyone.
I bought a SCT 4 bank from Chris at Power Adder Solutions and he put a base tune on it so I could get it to dyno/tuner with my On3 turbo install and head and cam and while nine yards. Well when I installed the chip there is a red light on. I looked online and found ideas to check and I doubled checked everything cleaned the hell out of contacts and trim case. It is a 1989 gt vert. It starts and runs ok without the chip installed. I even sent it back to power adder sultuons where Chris was able to burn it and even put in someone else's car. He said it was fine. Well I installed it again today same thing. The light is red and no start. When I turn key I don't hear injectors or fuel pump.prime any ideas or help would be great. Thanks in advance.
Sent from my PI86100 using Board Express
1989 GT Vert.. Major Changes for 2013 Wish me luck
Old setup from 2012 On3 Turbo, Trick Flow 170 Heads, Edelbrock RPM upper & Lower, Trick Flow Stg 2 cam, UPR K-member and control arms and Strang front and rear coil over, and UPR upper and lower rear control arms, MM frame connectors Fully Built AOD, 512whp
89BlackGtVert is offline
post #2 of 4 Old 05-06-2012, 11:51 PM
Originally Posted by 89BlackGtVert View Post
Hello, everyone.
Maybe an issue with your PCM
93GRNLX is offline
post #3 of 4 Old 05-07-2012, 03:22 PM
Paulie's Avatar
Did you clean the contacts on both sides?
Paulie is offline
post #4 of 4 Old 05-09-2012, 07:26 AM Thread Starter
I cleaned the hell out of them I was told by more than one person the ECU is prob bad. So I called Frank from PSI, who is doing my tuning. He said just bring it the way it is. He will figure it out.
Want To Buy Right hand red bumper side marker light warrior86 S197 and Coyote Parts 3 01-02-2012 10:25 AM
For Sale ➫➫➫ 03/04 Cobra Part out Black & Torch Red ➫➫➫ 2003snake Modular Engine Parts 329 10-09-2011 10:39 AM
Want To Buy 96-98 lazer red tail light bezels both sides hollyw58d Exterior Parts 0 02-15-2011 09:11 PM
Cold start problem: Start, stall, Start Whiterag 5.0/5.8 Engine Tech 2 11-30-2001 06:53 PM
"LOW COOLANT" light on rockspyder 94/95 Tech 9 11-27-2001 08:42 PM
