EDIS plug wire coil terminals - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 03-19-2012, 03:09 PM Thread Starter
05GT3V's Avatar
Im running an MS3 with an EDIS coil pack out of an Explorer and am having a hard time finding just the coil terminal ends so I can make a custom set of wires. Does anyone know where to get them?
Rob
Rob
'83 Capri RS, Boss Block 331, 65/67 Comp Turbo, TW170s, TFS stage 1 cam, MS3X, Explorer Coil packs
'98 Cobra Vert, Chrome Yellow
'13 Raptor SCrew
05GT3V is offline
post #2 of 8 Old 11-15-2013, 12:41 AM
Indo-Canuck-Yankee
Shaker666's Avatar
I'm having a tough time with the same problem. Did you find a solution?
'71 Mach 1: totaled - R.I.P.
Shaker666 is offline
post #3 of 8 Old 11-20-2013, 06:38 AM
Jack Hidley's Avatar
Just call up the plug wire vendor and give them the lengths. They will make you a custom set. That is what I did.
Jack Hidley
Jack Hidley is online now
post #4 of 8 Old 11-20-2013, 10:29 AM
Indo-Canuck-Yankee
Shaker666's Avatar
I make all my own wires since I have a good crimper and wiring tools. I ended up grabbing 20 or so EDIS ends from junkyard engines. The plastic clips can be purchased new from NAPA, but the boots and terminals don't seem to be available - I will end up decrimping and recrimping the terminals and using the used boots.
post #5 of 8 Old 12-15-2013, 09:26 PM Thread Starter
05GT3V's Avatar
I ended up buying a set of wires from Davis Unified Ignition. Ford LiveWires Performance Distributors Performance Distributors
Rob
'13 Raptor SCrew
05GT3V is offline
post #6 of 8 Old 12-22-2013, 05:14 PM
Goggles Pizano's Avatar
Having the same problem myself, actually worse, I'm looking for straight edis ends! So far no luck on the straights, probably have to make 'em... but check out Aurora Ignition Wires... boot #97525 and terminal 97510. Also Weapon X Performance boot# IWBK0001 and terminal IWC0004.
If anyone knows of a factory ford edis style coil pack application using straight ends...I would love to be pointed in it's direction!
GP
Goggles Pizano is offline
post #7 of 8 Old 12-22-2013, 06:44 PM
Indo-Canuck-Yankee
Shaker666's Avatar
GP
Yep, this is a legitimate issue, for sure. I've never seen straight coil pack ends and I don't think they were ever made by an OEM. I've only seen the 90* coil pack ends.
I have a set of Taylor 72623 and they have almost straight spark plug boot ends, though... 135* boots. The Aurora 97525 (good find, btw) is definitely the piece. Terminal pn 97510 is also the right piece! Haven't been able to find those ANYWHERE, although I never checked with Ford.
I posted your question on EFIDynoTuning.com because there are some people on that forum that really know some obscure info!
post #8 of 8 Old 12-23-2013, 09:38 PM
Cool thanks Shaker
Having trouble finding plug wire set I need Wicked03GT 5.0/5.8 Engine Tech 7 09-16-2011 11:15 AM
For Sale F/S: BNIB 2v Coil on Plug Conversion Harness CrystalWhite97 Modular Engine Parts 6 07-31-2011 01:07 PM
Need some plastic Spark Plug wire to Coil Pack hold downs.. anyone? Redsnake GT & SOHC 0 12-28-2001 10:23 AM
Trying to test my spark plug coil wire Need specs!! wazee 94/95 Tech 2 12-23-2001 04:13 PM
