Transmission codes 637,652,668 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-09-2011, 10:06 AM Thread Starter
v8powerv8jim's Avatar
Done a AODE to Tremec swap a while back in my 1994 GT,just received a base tune for my Tweecer with newly added 60lb injectors & BA2400.
I am now getting codes
637-Transmission Fluid Temp (TFT) sensor circuit above maximum voltage/ -40 degrees F indicated / circuit open
652-Torque Converter Clutch (TCC) solenoid circuit failure
668-Transmission Range circuit voltage above maximum voltage
The Tremec has just been rebuilt.
Im using an auto computer with both trans type & strategy set to 0 to disable AODE.
94 gt 342 Forged Stroker B50 block,faceplated TKO & Lakewood,Spec 3 clutch,HP 76mm Turbo,Victor JR heads,1.6 RR,B41 Cam,TFS Box R intake,90mm TB,Vortech Maxflo fuel kit/rails,60lb inj,MSD Blaster,Pro Billet & 6AL
v8powerv8jim is offline
post #2 of 2 Old 11-10-2011, 11:53 AM Thread Starter
Problem solved-The tune was rebuilt into a T4MO strategy,and no transmission codes now.
Still not sure why i was getting codes when auto functions were turned off with the Tweecer.
no start when hot gambling209 SVO/2.3L 12 04-21-2011 10:18 PM
For Sale ATF Built 5R55 Transmission with PI Multidisk Converter Included CJBlackmon S197 and Coyote Parts 6 04-11-2011 08:12 AM
For Sale ATF Built 5R55 Transmission with PI Multidisk Converter Included CJBlackmon Drivetrain Parts 2 04-10-2011 04:36 PM
For Sale Lentech AOD Strip Terminator Transmission jandmmotorsports Drivetrain Parts 0 03-24-2011 10:56 AM
T5 Transmission HELP! -Wraith- General Mustang Tech 50 03-18-2011 09:01 PM
