spark plugs? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 10-15-2011, 02:04 AM Thread Starter
spark plugs?
Ok so i just put a set of gt40 heads on my car and i need to know what spark plugs to run.
91vert5.0 is offline
post #2 of 2 Old 10-21-2011, 08:26 PM
THELAW1's Avatar
Iron or aluminum
89 Reggatta blue,Trickflow Intake,
1in spacer.65mmTB,GT-40 aluminum heads(X303),3000 Dynamic Converter, Motorcraft plugs 32c's ,E-cam,24lbs Injectors,Pro-M 76mm Mass air , AOD,shift-kit, modified valve body, 410 gear, Eaton
THELAW1 is offline
For Sale XP104 iridium spark plugs: $30 shipped set of 8 BerniniCaCO3 Windsor Engine Parts 0 03-21-2011 12:31 PM
Spark plugs bad after flooring accelerator?? redSVTsnake SVT & DOHC 9 02-12-2011 03:21 PM
Spark plugs for Dart heads richs347 5.0/5.8 Engine Tech 4 04-09-2006 06:27 PM
Where are the Spark Plugs on a 2001 GT 2001Ragtop GT & SOHC 5 01-02-2002 11:00 PM
What would cause the electrodes to break off on my spark plugs? 169mph GT & SOHC 4 12-05-2001 11:10 PM
