air charge temp sensor? HELP - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 10-13-2011, 12:55 AM Thread Starter
ok well i bought a set of gt40 heads that were ported and a explorer intake. on my lower intake there is no hole for the air charge temp sensor. wouldnt be a problem but i already put the lower intake on before seeing that little problem. now what i need to know is can i drill and tap a hole in the upper intake for the sensor or put it somewhere else like the intake tube somewhere. i have a c&l intake tube i know i would have to extend the wires thats not a problem i just need to know if it has been done and will it work. any info will be great guys thanks!
91vert5.0 is offline
post #2 of 9 Old 10-13-2011, 04:25 PM
boostdcoupe's Avatar
Trader Feedback: (30)
IIRC the reason the exp. intake has no sensor in it is 'cause the sensor is in the intake tube near the maf meter, in the airbox or something like that. when i put the MS on my car i relocated mine to the discharge tube from the blower so it didnt heatsoak in the lower as suggested by DIY autotune... so, put it in your C&L tube... it will be fine. extend the wires and put some loom on it.
replaced the 93'ish coupe with a 76 F100, 393, 11.5:1, TEA CNC 205 TW's, custom Hyd Roller, Super Vic, 830 HP, AOD, Edge custom conv., Silverfox SPT-MAC-TB.
boostdcoupe is offline
post #3 of 9 Old 10-13-2011, 09:25 PM
ACT
I read an article on here somewhere and a guy drilled and tapped his in the under side of the upper intake. Didn't have to extend his wires or anything. I plan on doing the same when I install my exploder intake.
snakedoc257 is offline
post #4 of 9 Old 10-14-2011, 02:27 AM Thread Starter
yea i seen one where a guy put it in the back of his intake inline with the throttle body where the fins are and it looks so bad lol. it doesnt seem to matter where it goes from what i have been reading... the bottom of the upper intake would work fine and be out of the way but i think im going to put it in the intake tube because there is a bung that i can tap and drill and its alot less money to replace that than the upper intake not that i would have to but just in case.
post #5 of 9 Old 10-14-2011, 05:51 AM
heres where i put mine...
post #6 of 9 Old 10-17-2011, 03:27 AM
87slutstang's Avatar
mine is just laying on the lower intake. runs perfect
408w 200 shot. 17.9 @ 85
87slutstang is offline
post #7 of 9 Old 10-17-2011, 07:39 PM
are you sure you aint from south central? LOL J/K.
post #8 of 9 Old 10-19-2011, 08:02 PM
Michael Yount's Avatar
The fact is - the processors for the 87-93 cars aren't that sensitive when it comes to ACT signal. But - I'd put it where it comes closest to stock. Yes - you can drill/tap the upper and install it there. It'll work fine. Second choice is the intake tube.
Michael Yount - Charlotte, NC - 82 Volvo 242 - 6.2L; '17 Mazda3; '16 CrossTrek
Michael Yount is online now
post #9 of 9 Old 10-20-2011, 01:07 PM
Nitrous SSC's Avatar
Your car is likely pulling timing then.
Bonneville 130 club member. (139.993) [email protected] in the 1/4.
Nitrous SSC is offline
Feedback air charge temp sensor? HELP 91vert5.0 Electronics and Entertainment 2 10-16-2011 12:37 PM
Charge air cooler hoses TonyG Superchargers 2 08-12-2011 02:31 PM
what air charge temp will a maf melt at ?? intercooler delete.. Ben Better Turbochargers 3 03-30-2011 09:29 PM
Custom Air Intake - Need Suggestions natx808 GT & SOHC 4 12-27-2001 08:57 PM
Home Made MAF Info.(Cold Air Induction) 96Stang GT & SOHC 1 12-04-2001 10:55 AM
