91 Fox tuning issue..need help.. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-27-2011, 03:54 PM Thread Starter
Prone to Violence's Avatar
Trader Feedback: (23)
91 trunk Dart 347 Comp block Dart Pro 1 heads YSI Vortec s/c, Aeromotive fuel system, 60lbs inj. Car was tuned before with 306 different heads, s/c was the same inj. was the same. Basically everything was the same on the car except heads and new block. The problem is that at 10 degrees timing the car idles at 1500-1800 rpm. There are no vacuum leaks..throttle cable is not stuck, tps set at .98..I was hoping to be able to drive the car before it goes back to the tuner to break in new clutch. Can you give me any ideas?
91 Coupe Dart 347 YSI fogger
85 GT 408 8.58 167mph
2004 Lightning 12k 450rwhp
2008 Acura MDX AWD Helion TT 10.44
Prone to Violence is offline
post #2 of 4 Old 10-03-2011, 03:15 PM
boostdcoupe's Avatar
Trader Feedback: (30)
what kind of EMS have you got? i would say though, from what ive seen the timing needs should be substantially different beteeen the two motors (306-347).
replaced the 93'ish coupe with a 76 F100, 393, 11.5:1, TEA CNC 205 TW's, custom Hyd Roller, Super Vic, 830 HP, AOD, Edge custom conv., Silverfox SPT-MAC-TB.
boostdcoupe is offline
post #3 of 4 Old 10-03-2011, 11:52 PM
need to verify TDC with zero mark on the balancer and then recheck base timing. I am assuming you are using the Ford EEC and a chip ?
93GRNLX is offline
post #4 of 4 Old 10-05-2011, 12:00 PM Thread Starter
yep Balancer is right,
Favor to ask of anybody who's done the fox TB conversion seijirou 94/95 Tech 16 04-25-2011 06:28 PM
How well can a Fox Body handle??????? Stangposse Road Racing/Auto X 23 03-16-2011 01:54 PM
eMERGENCY brake cable issue with 10" wheel on fox 87grabbervert Wheels and Tires 1 02-27-2011 05:19 PM
Rockefeller wants to silense FOX and MSNBC? JohnC76 Politics 21 11-22-2010 04:18 PM
Lou Dobbs moves to Fox r.barn Politics 3 11-12-2010 07:22 PM
