electric fan pinout on fox? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 09-25-2011, 10:46 PM Thread Starter
white93pony71's Avatar
Trader Feedback: (23)
I have been looking into purchasing a quarterhorse and b/e to tune my car with. I downloaded b/e and began to play with the program to see if it is the road i want to take. I was playing with the a9l info and noticed that there was a place to enable the electric fans. is there a location that you could add a pinout on an a9l computer and have fans on a fox without buying an expensive controller?
white93pony71 is offline
post #2 of 10 Old 09-29-2011, 11:29 PM
indy2000's Avatar
not all eecs work.
indy2000 is online now
post #3 of 10 Old 10-30-2011, 04:08 AM
This link should be helpful...
fordfuelinjection.com/files/A9L_E-Fan_How-to.pdf
rogerdahlman is offline
post #4 of 10 Old 10-30-2011, 09:45 AM
indy2000's Avatar
that link does explain how to test if your a9l will work.
keep in mind it still doesn't address the proper way to cycle the fan if you have a/c.
post #5 of 10 Old 10-30-2011, 07:42 PM
usually there is an address in there somewhere for AC fan, just depends how much the hac has been commented.
'87 GT- SOLD!
'86 Grand National- LZ9 swap in progress, built 2004R, ???turbo, Alky
34blazer is offline
post #6 of 10 Old 11-07-2011, 02:20 AM
Check out page 2 of the last link for how to test if the PCM will work using a volt meter and a pull-up resistor.
This link shows how to turn the fan on with the AC.
wiring electric fan to computer - Mustang Forums at StangNet
This link also has a lot of good general information
Ford Fuel Injection » Download Files
Hope this helps.
post #7 of 10 Old 11-07-2011, 07:40 AM
indy2000's Avatar
There is no pressure control valued in the eec, therefore it is still NOT the proper way to cycle the fan when the a/c is on.
You would still need a pressure switch that enables the sensing circuit in the eec.
post #8 of 10 Old 11-07-2011, 12:39 PM
so the eec doesnt have a AC on/off circuit? i could have sworn i saw a pinout for that, or maybe im getting mixed up. but ive only dismantled the ford harness and installed a totally different one.
'87 GT- SOLD!
34blazer is offline
post #9 of 10 Old 11-07-2011, 11:08 PM
indy2000's Avatar
yes for the LPS, not fan cycling.
post #10 of 10 Old 11-15-2011, 08:02 PM
BobCat's Avatar
I've used the A9 series of processors to control the elec fan on numerous Foxes for a couple years now and I've never seen a processor that wouldn't work...
94 GT 327 S-trim 4r70w yadda yadda
BobCat is offline
Taurus Electric Fan Install on a Fox COMPLETED oatburner99 General Mustang Tech 13 06-27-2011 04:00 AM
Anyone use Fox Body Mustang Parts LLC Electric Fan Kit? Stangit50 General Mustang Tech 1 05-22-2011 10:33 AM
Electric Fan Upgrade with Stock Fox Electrical System 5.0PEV General Mustang Tech 2 04-28-2011 01:05 AM
electric fan: fan speed controllers? BerniniCaCO3 General Mustang Tech 21 03-23-2011 09:29 PM
Want To Buy Need a Thing Electric Fan for a Fox 91svtcoupe Electronics and Entertainment 0 02-13-2011 11:13 PM
