computer options? please help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-04-2011, 03:13 PM Thread Starter
strokergt's Avatar
Trader Feedback: (18)
ok ive got a classic fast in my 98GT (4v swapped turbo car) the car just runns like poop, it has erratic idle and you cant drive it normal, its either you gotta be on it or not ect. it also will randomly cut off if you stop too fast or sitting at a stop light
now here is the question... do i swap the classic fast out for a XFI system, or go back to the stock setup and put a chip in the computer?
anyone have experience with the XFI vs CLASSIC fast? id kind of just like to have ppls thoughts on this
also this is a street car too
98GT.... little this a lil that
The beast is on steroids
current project:.20 over 4v, TH400, billet 76MM
strokergt is offline
post #2 of 5 Old 09-04-2011, 04:23 PM
Trader Feedback: (41)
It sounds like its not tuned properly now?
stangjumper is offline
post #3 of 5 Old 09-04-2011, 05:05 PM Thread Starter
strokergt's Avatar
put it on the dyno and tuned it, but im not sure if the classic fast is the issue, the a/f ratio doesnt read all the time and from what a few ppl say its a bad setup and nightmare to tune with the modular setup because with the classic fast you have to piggy back it with an EDIS module..
wasnt sure if ppl had experience with the XFI system and like it over the CLASSIC system or if i just need to put the stock setup back in it and throw an SCT chip in it and let it ride
post #4 of 5 Old 09-04-2011, 10:53 PM
I don't know anything about using it with the edis setup. I tune my friends bbc with n 8-71 blowet and have no problems. It does the job
Are the newer computers better? Sure. Is it what you need? I'm not sure. Sorry
post #5 of 5 Old 09-06-2011, 10:04 AM
Unless something is mechanically broken, it should be possible to tune it to avoid this. Although not written specifically for FAST, we have some tips on tuning the fuel and spark tables to get a good idle that may help.
Tuning idle with MegaSquirt
Matt Cramer
Matt Cramer is offline
On3 has done it again...... 2Guard Turbochargers 179 08-13-2011 03:29 AM
Abbott and Costello, selling a computer Streetstrip01 Lounge 2 03-10-2011 09:08 PM
Computer Phone Cover Options ITSTOCK Lounge 9 12-28-2010 05:28 AM
Conversion Harness to put earlier A9L computer in place of the obd11? flynbrian EEC Tech 2 01-09-2002 10:36 PM
