Can someone help me out? (need a electric multimeter) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-19-2002, 10:26 AM Thread Starter
Unhappy Can someone help me out? (need a electric multimeter)
Hey guys I have been having troubles with my battery going dead the past few days. I really dont think that it could be my battery. Its a optima yellow top that is only 3 months old!! Anyway, I went out with my multimeter and tested the terminals (in the trunk) and when I test them I dont get a complete open loop. Its not closed enough though to make the tester beep.
If someone has a decent multimeter could they run out and do a connection test on there battery terminals to see what they get???? Or if anyone knows off hand
jplayer is offline
post #2 of 3 Old 05-19-2002, 11:57 AM
sn95mustang347's Avatar
first of all have u tested the alternator?
i dont know why you would test terminal to terminal, but since you were waiting for a beep, it sounds like you were using a diode tester instead of the ohm meter.
if u feel like u have an ignition off draw, the best thing to do is use an amp meter. place it in series between the positise terminal and the positive cable. make use all the inside lighs r off and nothing is running. check the amp reading, then start pulling fuses one at a time. if you pull a fuse and the amps drop off then you know something in that circuit is drawing from the batt.
sn95mustang347 is offline
post #3 of 3 Old 05-19-2002, 03:13 PM
1quick95's Avatar
"start pulling fuses one at a time."
I do this with the negative cable disconnected and a test light from the cable to the battery.If the light is on,there is a short,when the light goes out,no short.I hook the light up,and do the fuse test,and check to see what the fuse cuts power to.Good Luck.
Tony
New project : Dads 91 LX 351W rebuild
1quick95 is offline
Meziere electric WP vs Mech Eldebrock WP ACJ Turbochargers 8 04-07-2014 08:08 PM
Magnum T56 Electric Speedo Conversion Alexandros General Mustang Tech 0 05-03-2012 12:42 AM
Can I use electric wire and electric rope together from6to8 Lounge 8 03-31-2011 01:04 PM
Small Carb Electric fuel pump- No regulator?!?! masterjr33 5.0/5.8 Engine Tech 9 03-01-2011 09:03 PM
Are electric water pumps really that helpful? XSPOWER 5.0/5.8 Engine Tech 36 02-22-2011 09:17 AM
