SN95 brothers, I need your help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 05-08-2002, 06:42 AM Thread Starter
Fordman50's Avatar
Exclamation SN95 brothers, I need your help
I am finnishing us a PITA Procharger install which requirded me to move the battery to the trunk and to move the fuse box. Now I cannt find where one plug goes Can someone look under the hood and tell me?
The plug is black and round and has 4 wires going to it (there is one near by with only one wire). Its on the same wire loom that basically starts at the altenator and comes accross the top front of the engine to the drivers side where it slits 3 ways. One goes to the fuse box (with to light grey wires), one goes to the AC compressor and just 5 inches upstream is this round plug. WHERE DO IT GO?
Got 10s? [NA]
Fordman50 is offline
post #2 of 10 Old 05-08-2002, 05:17 PM
put up a pic of the connector. I'll see what i can find.
JK
JohnnyKnoxville is offline
post #3 of 10 Old 05-08-2002, 05:48 PM
I'll try to help you out, I have a 94 Mustang GT, but I don't know what the connection is, found the three way split, one to A/C, one to fusebox, and the one you're looking for seems to plug in right under the original location of the fusebox, loops down under and back around and enters the fenderwell through the hole for your windshield washer fluid resevoir. After that I'm not sure where/what It goes to , and I can't say if it's round as I can't see it that well but it does appear to be a 4 wire connection. I hope this helps you.
Ashwood is offline
post #4 of 10 Old 05-08-2002, 05:51 PM
94bonestocker's Avatar
I just looked at my 94 gt, and it's right under the fuse box. It might have got stuck behind the fuse box also. It's maybe at the most 2 inches under the fuse box. Just look really good around that area. I hope this helps, let us know if you find it
Hatch 351W
94bonestocker is offline
post #5 of 10 Old 05-08-2002, 09:48 PM Thread Starter
Fordman50's Avatar
Thanks guys. Just to be sure, there is one the looks very simular near my fuse box now but its slightly smaller and a single wire (had to unplug to see) The one Im looking for (and it may very well be what you all are seeing) is bundled but you can see 4 wires, 2 black, one green and another one I forgot. Its JUST 5 inches down stream of the AC plug. Unfortunately, there is a big blower where the old fuse box was and I cant see much.
Got 10s? [NA]
post #6 of 10 Old 05-08-2002, 10:49 PM
94cobra2615's Avatar
Cool
Im checking now for you...
94cobra2615 is offline
post #7 of 10 Old 05-08-2002, 11:04 PM
Sorry it took me about five minutes I think the plug you are talking about has four wires going in and 3 wires coming out of the other plug(this is the one it plugs to). So plug the four wire plug to the plug with 3 wires coming out of it.
post #8 of 10 Old 05-09-2002, 07:21 AM Thread Starter
Fordman50's Avatar
OK, yeah so where does it go????
THANKS
Got 10s? [NA]
post #9 of 10 Old 05-09-2002, 10:39 PM
SORRY I tried
post #10 of 10 Old 05-10-2002, 06:30 AM Thread Starter
Fordman50's Avatar
Thumbs up
THANKS GUYS! I found it under the fuse box!!!
Got 10s? [NA]
