Is there a way to get rid of the annoying door chime? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-05-2002, 05:51 PM Thread Starter
Question Is there a way to get rid of the annoying door chime?
I hate it when I open the door and leave it open. Should I just glue the black knob in or is there a wire of some sort that can be removed or cut. Thanks.
94 Cobra #2490
FOR SALE:
94-95 Cobra intake
NEW FMU
ASP pullies
PM me...
94sssnake is offline
post #2 of 6 Old 05-05-2002, 05:55 PM
check you haynes manual if you want to know for sure, but otherwise just leave it open and stick your head under the steering wheel and listen to where the siren is. once you find just snip the wires going into it.
FordFactory is offline
post #3 of 6 Old 05-05-2002, 09:34 PM
US Army Active Duty
SVTCobra347's Avatar
Trader Feedback: (34)
Look on the car body between the door hinges-there is a little black spring loaded push-button switch. Just remove it and cut the wires (leave enough to re-install later) and splice the wires together. If this gives you a constant ding, then just leave the wires cut and tape or silicone or heat shrink tube them really good. I'm pretty sure that will work-did on my ranger. If there's more than 2 wires then find the hot wire and either wire them all together or cut'em all and seal them.
SVTCobra347 is offline
post #4 of 6 Old 05-05-2002, 10:26 PM
Eric 94 Cobra Coupe's Avatar
You can do it without cutting anything. Just stick your head up under the driver's side and unplug the harness going to the "dinger". My friend did it 15 minutes after I brought it home.
2003 Cobra Coupe
Dark Shadow Grey
"Ever seen how fast a horse runs after it's been bitten by a snake?"
362 RWHP/355 RWTQ SAE corrected. 1000 miles, stock w/o silencer.
401 RWHP/370 RWTQ SAE corrected. 3800 miles, Steeda CAI, Borla Stinger.
Eric 94 Cobra Coupe is offline
post #5 of 6 Old 05-05-2002, 11:21 PM
Banned
Originally posted by 94sssnake
That post didn't work... is there another link?
http://www.cyberstangs.com/stangman/...doorchime.html
post #6 of 6 Old 05-06-2002, 12:25 PM Thread Starter
Thanks for the help guys!
94 Cobra #2490
FOR SALE:
94-95 Cobra intake
NEW FMU
ASP pullies
PM me...
