Installing gauge - where do I tap into the factory gauge light circuit ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 04-25-2002, 05:10 PM Thread Starter
SC95's Avatar
Unhappy Installing gauge - where do I tap into the factory gauge light circuit ?
Does that make sense? I'm putting an aftermarket gauge in and want my factory light switch to activate this light also and possibly even be able to dim it with the rest of the interior lights.
Can anyone help me?
95 GT with some stuff
02 Z06 bolt-on's
70 torino cobra 429/C6
SC95 is offline
post #2 of 7 Old 04-25-2002, 05:24 PM
Eric 94 Cobra Coupe's Avatar
I haven't done it on the Mustang, but I added inside floor lighting in my old truck. What I did was probe the light switch bundle with a voltmeter for the interior lights then tapped that wire. You may be able to do the same from the dimmer wiring if nobody has an easier way...
2003 Cobra Coupe
Dark Shadow Grey
"Ever seen how fast a horse runs after it's been bitten by a snake?"
362 RWHP/355 RWTQ SAE corrected. 1000 miles, stock w/o silencer.
401 RWHP/370 RWTQ SAE corrected. 3800 miles, Steeda CAI, Borla Stinger.
Eric 94 Cobra Coupe is offline
post #3 of 7 Old 04-25-2002, 05:34 PM
94CobraPace's Avatar
A easy place to tap the dash light (dims & brightens with dash lights) is pop the clock off and use a test light to find the wire that comes on with the lights and dims & brightens with the dash light. I cannot remember the color.
Another option is to remove the dash and locate one of the dash lights and tap into it from there.
Hope this helps.
2010 Shelby GT500, Kona Blue W silver stripes.
2007 Shelby GT500, Vista Blue with Tungston gray stripes, 1 of 119, Wifes car...
94 Cobra Pace car Convertible # 591
2001 Cobra vert # 2001 SOLD
94CobraPace is offline
post #4 of 7 Old 04-25-2002, 06:28 PM
Maybe even the radio, easier to pull out and get to the wiring?
DZAHER is offline
post #5 of 7 Old 04-25-2002, 07:11 PM
I just installed 2 gauges and I tapped into the wires at the headlight switch itself. I used a test light and touched the contacts on the back of the switch untill I found the one that had the dimmer.
This has worked great for me.
Good luck!
vibrantred94gt is offline
post #6 of 7 Old 04-25-2002, 07:14 PM
I have done the same thing as vibrantred94gt and it worked perfectly. That is the way I would suggest doing it. Take it easy.
-Billy
Green9550 is offline
post #7 of 7 Old 04-26-2002, 08:08 PM Thread Starter
SC95's Avatar
Hey everyone, thanks for the help.
02 Z06 bolt-on's
SC95 is offline
Sputtering while driving shiz1125 5.0/5.8 Engine Tech 16 04-03-2012 04:14 PM
Help finding wiring diagram for factory CD player? Question re: adding circuit also? DuffManRHA SVT & DOHC 10 10-19-2011 05:58 PM
Help finding wiring diagram for factory CD player? Question re: adding circuit also? DuffManRHA General Mustang Tech 0 10-18-2011 07:37 PM
For Sale Autometer Gauge Lunar Gauge Cluster, 5" Tach w Shift Light, Gauge pod, FP Gauge HighPsi5O Electronics and Entertainment 12 10-11-2011 04:29 PM
Need Wiring Diagram for Cruise Control System dan89lx General Mustang Tech 6 03-27-2011 07:24 PM
